EM TuningAH Fabrications
Results 1 to 7 of 7
    Dec 2006
    halifax, west yorks
    67
    rs4 front brakes
    hi guys, fairly new to the s4 scene as i have uped from an s3. i have a 1999 s4 with a few light mods (miltek exhaust, stage 1 chip). the only thing that lets the car down are the brakes. it is fitted with lucas twin pots on the front and was wondering if the ate twin pots off a rs4 will fit and also will they improve the brakes. would love to put some 4 pots on but am struggling to find any at a decent price and also what others will fit. i have seen some ate twin pots and 360mm discs for ok money so was just wondering if they are any better. cheers
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,876
    Yeah rs4's bolt straight on iirc
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Oct 2008
    Glasgow
    430
    Avoid using the b5 rs4 front brakes, they are poor and very expensive when it comes to replacing discs.
    Either go for some 6 pot porsche calipers with amg ml55 discs (need slight modification but nothing major) or b7 rs4 front brakes, but again this is more expensive than the porsche option, and i am not a fan of the b7 setup (i use it on my b5 rs4 and think for what it is and the expense there are much better options) porsche setup being one of them.
    Jun 2012
    Penzance Cornwall
    77
    i am running the Porsche 993 GT2 set up with modified bells, i was going to ditch them in favor of RS6 but i have changed the pads to Yellow Stuff and the brakes have been transformed
    jcb
    Sep 2005
    uk
    4,070
    you can pick up 8pots and discs for well under a grand now.
    I have them on my B5 cost me about £900 all in (inc custom pipes)
    the bolt on part is the headache remover! modifying bells, adaptors etc is a pain
    Jun 2012
    148
    I'll be going for K sports when the time comes :thumb:
    Jul 2012
    Guildford
    96
    Have you tried rebuilding the twin pot lucas? I just did this on mine and its like night and day, £29.50 for the bits form Big Red. Mine had obvious signs of being rebuilt before also so it must be very common, I dont know any other car I have owned that would be on its second brake calliper rebuild at 12 years old.
  1. B5 rs4 front brakes
    By Dane in forum For Sale/Wanted - Audi Parts
    Last Post: 13th September 2012, 07:47
  2. Audi RS4 front brake disk
    By wazazz in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 26th October 2009, 19:13
  3. RS4 front brake pads
    By klauster in forum Parts Requests
    Last Post: 12th May 2009, 10:01
  4. RS4 front brakes
    By andybnwc in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2009, 13:20
  5. what is needed to make b5 rs4 front brakes fit???
    By M22_PRE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th August 2008, 13:07
