Sky InsuranceAH Fabrications
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By aragorn
Thread: One of those days....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Decided i'd finally get round to tackling a job on the car thats been needing done for a while.
    Theres an exhaust blow when cold, and under load theres a nasty farting sound. I suspected the gasket between the manifold and head, or the manifold and turbo, so i ordered up some new bits and decided i'd get them changed.
    After some preliminary steps, i had this:
    I hate touching turbos, as the bolts always snap, and sure enough, one did (probably not helped by me using some random crappy bolts from the spare bolt box, rather than genuine audi ones when i fitted the turbo last year):
    Not a huge deal, i was half expecting it, and i figured i just pop the turbo off and get the bolt removed.
    Continued on, removing the manifold bolts, then noticed one was missing. At first i thaught perfect, i've found the cause, i'll just chuck a new stud in there and we're sorted.
    As i worked at removing the rest of the bolts, a realisation hit me.... thats not fallen out, its snapped
    Sure enough got the manifold off and it was snapped, about 5mm inside the head flange.
    Rage ensued, due to its position its inaccessible with a drill, and even if it was, drilling something like that is bound to end in tears. After some thought, i decided to remove the head, and take the head into the local engine shop to have them sort it.
    Wont get it back until monday or tuesday, and i'm now waiting on bolts and gaskets and various other bits too.
    Car looks sad:
    adidasandy likes this.
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    I hate a simple job that turns out to be a nightmare.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,652
    Gutted mate.
    I hate it when jobs go like that.
    At least its a good oputunity to bolt in new and better bits like ermmmmmmmmmm......................yeah.
    Good luck.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Aug 2010
    2,866
    Hhhhg hhmmm ... RODS !!
    exactly what i was thinking scott lol
    "Stick a V8 in it!"
    14,900
    Quote Originally Posted by Bradderz_1988 View Post
    Its already got rods in it, fitted them when I rebuilt it last year
    Aug 2010
    2,866
    What rods you running ? You got pistons or standard ??
    Is this shed ??
    Im confused as you do have 3 B5's lol
    Im toying with buying a used block and getting it rebored and fitting a 2.0 crank just need to look in to it a bit more as not to sure if they use differant rods/pistons ive been looking at some gt turbos ive found one that tickles my fancy but its off a diesel i think but its internally wastegated and looks similar to some gt30's and will need a custom built manifold and downpipe. Just wana build my own motor really lol
    "Stick a V8 in it!"
    14,900
    Yeh this is shed. Annoyingly i've got more similar fun to be had on the avant when its new turbo comes, probably in the next week or so
    Brute rods from PagParts in the states, stock pistons/block/crank.
    If you go for a 2.0 crank you need different pistons. You use the same rods as normal, but the combination of the longer crank and standard length rods would make the pistons stick out the top of the block. So the stroker pistons have the pin mounted closer to the top of the piston, so it doesnt stick up.
    On an AJL, you also need to modify the block itself for clearance at the sides, and i believe you need to alter the drive gear for the oil pump, or it catches on one of the rods.
    Aug 2010
    2,866
    Right looking at this turbo would you say its ok for a custom build ??
    Turbocharger Garrett GT3576 ISUZU 6HK1 XS w/ Gasket | eBay
    "Stick a V8 in it!"
    14,900
    Its MASSIVE, GT35's probably a 5-600hp turbo. Which means lagtasticness.
    Its also probably not a genuine garett, although i have heard good things about kinugawa in the past. While they make copy turbos, they seem to do a good job of making copy turbos.
    If you wanted to go down that route, Kinugawa do some TD05 and TD06 turbos which could fit the bill, Welly is using an FP-Green, which is a hybrid based around a TD06 and has had pretty good results (444hp). He also ran a TD05 of some description previously and managed good figures from that too (~380 iirc).
    Aug 2010
    2,866
    Nice to know well it will be a on going thing if i do go ahead and do it just really like to build my own motor and do a custom setup thats a bit differant.
    Is this what your on about
    Kinugawa Turbo Turbocharger TD05H-18G AR 8cm w/ 3" cover T25 Flange 370 HP | eBay
    "Stick a V8 in it!"
    14,900
    yeh something like that
    "Stick a V8 in it!"
    14,900
    Finally got it sorted yesterday!
    All went back together fairly smoothly once i got all the parts. I did at one point have an "oh ****" moment when i realised i'd sent the head to the machine shop with the inlet valves on cylinder 1 sat fully open, and the head had been sat down on them.
    Luckily they were fine, though i did make starting the car somewhat nervewracking :P
    After a test drive it seemed my missfire had got worse, so i swapped a couple of the coils out and it went away Another issue easily fixed.
    When i had it apart i also replaced the N75 valve, to see if that would cure my weird boost-lag after gearchanges. The valve i removed was dated 11-96, which means it came off my old FWD A4 having done 195k. Not entirely surprising that it might be a bit worn out! New valve fitted, and it now seems much smoother and finally, no more lag
  1. Theres one born every day....
    By PaulAr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th June 2008, 14:30
  2. How much is one of those?
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2008, 18:19
  3. Met a special some one the other day.....
    By madalex in forum General Chat
    Last Post: 26th October 2007, 07:15
  4. Met a special some one the other day.....
    By madalex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2007, 08:11
  5. Awwww, I wanted one of those
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2005, 09:52
