Chris NottMonster Motorsport
    Jul 2012
    turbo flutter-stutter
    Hey guys, new to Audi's, just picked mine up Monday. a bit of an issue has crept up, when I accelerate, it begins to flutter or stutter a few times as the RPMs go higher. it is the worst when cold, but still does it (although less) when warmed up. one guy suggested that it was a wastegate issue on the Turbo...what do you think?
    it is a 97, 1.8T quattro.
    thanks.
    griswold's Avatar
    340
    I had the same thing with mine changed lots of parts, looked for boost leak.
    Turned out to be the coils.
    Trial and error till you find the problem.
    I changed dv,vac lines,cts,maf,plugs then finally coils all 4 £80del. buypartsbuy
    Drives great now.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Jul 2012
    I'll check it out, thanks.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    my parents did this and it was a split hose off the inlet manifold.
    TD5 Land Rover Defender build
  1. B5 Tip fitted. Turbo flutter while on boost.
    By MintyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2012, 20:22
  2. ' turbo flutter ' ?
    By jamieA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2012, 23:42
  3. Flutter sound...turbo?
    By mikeyw in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th October 2011, 14:18
  4. Turbo 'Flutter'
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2010, 21:13
  5. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
