Chris NottEM Tuning
    a4-er's Avatar
    Feb 2012
    21
    Temp sensor (g62)
    Sometimes when my car is warm, and i let the engine run in free gear, the car stops. Then it may be hard to start, and when it starts, the car runs really bad. But if i stop it and start it and it starts right away, it runs fine. Got a friend reading the fault codes. And what i got was sensors for coolant temp. And engine speed. Do i have to change both sensors, or do i just have to change the coolant temp sensor? Some say the coolant temp sensor problem may have led to the engine speed sensor problem. Anyone familiar with this problem?
    2001 a4 1.6
    a4-er's Avatar
    Feb 2012
    21
    Fixed. It was the crank sensor.
  1. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  2. Temp Sensor (G62)
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2010, 16:42
  3. G62 Temp Sensor Location
    By gazsutton in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th June 2010, 09:33
  4. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
  5. S3 Temp Sensors
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2003, 16:53
