AH FabricationsBadger5
Page 9 of 22 FirstFirst ... 234567891011121314151619 ... LastLast
Results 321 to 360 of 852
Like Tree96Likes
Thread: What have you done today?
  1. #321
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    No-one in the universe has slate grey interior parts, give up and fit black ones!! :P
    Never!!
    They are out there somewhere and someone breaks one with it i will pounce....................at wish they was cheaper and then go get black.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  3. #322
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    I converted one side of this Chorus stereo from red led to white for fun.
  4. #323
    Jun 2012
    Ireland
    59
    brought the car for NCT(Ireland) and failed on cv boot and i cant believe they failed on missing lower door mouldings..... CV boot 10e and door mouldings 170e
  5. #324
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Quote Originally Posted by gedi View Post
    if there hanging off and have a sharp edge or can injure pedestrians they can fail it !! If there not there at all then id be having words and take it to your NCT ministry and report the testing station.
  6. #325
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    http://www.facebook.com/photo.php?v=...66437708848337
    I got mine running, she has a small coolant leak that needs sorting
  7. #326
    Oct 2009
    190
    Finally swapped my motor blower today. I've come to terms we just ain't having a summer so at least I can make the inside of my car lovely and hot.
  8. #327
    Jun 2012
    Ireland
    59
    Bradderz_1988 they are completely of the car its only them little studs left on the doors. well it was about time to get them mouldings anyway i was delaying for over a year so maybe its a good thing the car gona look better now..
  9. #328
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    is it worth seeing if ScottB5 group buy source can give you a quote for delivery to Ireland?
    ScottD3 likes this.
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
  10. #329
    Jun 2012
    Ireland
    59
    i ordered them already from german auto spares cause i have to bring the car to a test center in couple of weeks so im a bit in a hurry, but thanx anyway Sulli79
  11. #330
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Don't seem right them failing you on a bit of trim missing.
    WE could have sorted something out if you could wait.
    Next time?
  12. #331
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Testing out my test rigs for clocks and radios.
    Even got VCDS working.
    Clocks
    Stereos
  13. #332
    Aug 2010
    3,135
    Well been busy all day, went down to my works to do the rear wheel bearing all went smoothly apart from the abs sensor bolt snapped but its that tight i just left it and disconnected from under the rear seat, got the old bearing out new one pressed in bolted all back up jobs a good un until on the way home the noise is still there arrgghh jacked it up when i got home theres no play in the wheel doesnt feel rough used an skf one so im going see about getting a replacement monday as ordered it through our parts so should have a warranty thats if the bearing doesnt blow when i press it back out (no doubt it will lol) going to do the o/s/r one aswell just to be sure but its definately coming from the n/s/r.
    Whilst at work i got cracking with both front cv boots n/s/f was the better one of the two as the o/s/f required undoing the control arms to remove the shaft the n/s/f has loads of room to just pull the shaft.
    Few pics lol
    Ready for the joint
    All cleaned and greased
    My wash tank lol (diesel)
    Joint on and boot clamped
    All cleaned up ready to go back on
    All on bolted back up.
    Now since doing these i think ive dislodged the abs sensor or theres some crap in the reluctor or ive cracked it when tightening the bolt on the driveshaft with my impact gun as the abs is kicking in below 20mph checked with vagcom and its saying drivers front implausable signal intermittent iirc another job to do next weekend lol
    Also got my seatbelts swapped out and replaced the airbag ecu all went well and also fixed my cup holder that wouldnt eject unless you pulled it as it wasnt sitting flush.
    Few more pics lol
    Half stripped
    Found you !!!! Lol
    The bit jamming my cup holder which is now back in and working
    Also found this connector is it for the orginal concert tape deck or something else ???
  14. #333
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Quote Originally Posted by Bradderz_1988 View Post
    Think that's another ground that goes on the back of the stereo casing.
  15. #334
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    I'd be leaving the bearing alone until you've done the other side.
    TD5 Land Rover Defender build
  16. #335
    May 2012
    RETFORD, NOTTS
    1,753
    Today I spent over a grand on new diagnostic equipment!
    Still cant read the ABS fault on a family members renault though
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  17. #336
    Jan 2011
    Aberdeenshire
    646
    Been a bit busy recently with a new job, so not much time for the cars!
    However, I changed front calipers on both cars within the last month or so, the ones I had were costing me a fortune in pads and discs - lesson learned!
    I've got the rears to do on the saloon, but haven't had time yet.,
    My one (saloon) is due its test Monday, I've already put it in and got a fail sheet.
    Nothing bad considering - almost all the bits are due to my road - one front and one rear cracked spring, two tyres cut on the inside sidewall by rocks in the road (new last year too!), fuel pipe leaking (got hit by rocks), horn not working ( fuse blown - the avant did the same last year??) and an advisory on the NSF CV boot.
    I got Bilstein B6 shocks, Lemforder strut mount, Audi front springs and Suplex rears all from Jason at All German, along with a Febi CV boot. (shame I couldn't have read your write up first Bradderz!)
    The suspension wasn't too difficult - the rear towers were rotten,so I had to wheel out the Oxy-Acetelyne and put in a couple of plates. This seems to be an issue, as the Avants were the same so bear that in mind if anybody else is looking to do Quattro rear shocks. They go at the back(inboard) - so you only see when you remove them.
    The front was painless enough - it went pretty much the same as I said in my previous write-up.
    I cut out the leaky fuel pipe and spliced in a new length and changed the front CV boot.
    The boot was not as easy as I hoped. I don't have a cone, but as I had the strut out it should have been simple to pop the joint off and change it in situ. Unfortunately I couldn't press the joint off the shaft using the old bolt, so had to take off the driveshaft and give it some welly in the workshop. That did the trick!
    Took it for a test drive and it feels a lot better. The old shocks were done, although nothing actually visibly wrong with them, once off they were very tired.
    The Avant is due next month, so I will wait with bated breath!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  18. #337
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    You all seem to being suspension work on your motors mate.
    When you getting a proper drive way?
    Today I'm updating one of my RNS-d units and testing the remote switches with it.
    At the moment, the remote switch unit does not work.
  19. #338
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    not done anything to my A4 today but ive been stripping one of my B5 passats for it to head to the crusher tomorrow..
    over the weekend ill be dropping the subframe, engine and gearbox out my other B5 passat for it to head the same direction of the one I stripped bits off today..
    anyone ever fitted a power socket in the boot? I took the ones out the rear of my passat today and I fancy getting it in the boot of the A4.
    where would be the best place to take the feed from?
  20. #339
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Quote Originally Posted by jbh325i View Post
    I assume you got a PFL A4 B5?
    Got a tow bar?
    I used the feed for that for my 3.
  21. #340
    jbh
    jbh's Avatar
    TDi lover
    704
    Quote Originally Posted by ScottB5 View Post
    Got a tow bar?
    PFL ?? you have lost me there Scott ..
    Ive not got a tow bar yet but it will be on the to do list
    did youre tow bar have the twin electrics?
  22. #341
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    PFL, PreFacelift and FL is facelift. B5s prefacelifts was from 96 to about 99ish.
    My towbar did have the twin electrics but I've removed it.
  23. #342
    jbh
    jbh's Avatar
    TDi lover
    704
    ahh right gor you now.. yea my car is PFL in that case.
    was it the secondary socket you wired it to? I was thinking on running a live from the battery through a 20 amp inline fuse and even having a switch on it somewhere. I did use the one in the rear of the passat and did find it handy so I know it would be used
  24. #343
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    20amp is a bit big. 10amp would be more than enough.
    I wired in 2 12v sockets and 1 240v inverter.
    if you got an avant, look out for facelift rear boot sides, they have a pop out 12v socket.
    I'm not sure on the Loons.
  25. #344
    jbh
    jbh's Avatar
    TDi lover
    704
    mines is the avant.
    Ill get a look in at the breakers hopefully later today.
  26. #345
    griswold's Avatar
    340
    Aircon gas top up and finally fitted dash rings but wish i'd rubbed them over with wire wool to make them look like brushed alu to match interior. Fit new rear drop links later.
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
  27. #346
    Jun 2012
    Ireland
    59
    CV boot replaced and lower door trims installed ready for car retest.
  28. #347
    jbh
    jbh's Avatar
    TDi lover
    704
    bought S4 side skirts and thresholds from jcb will be looking forward to picking them up and getting them fitted..
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
  29. #348
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Today I change my pollen filter for a carbon activated one.
    Replaced my fault AC fan (which decided to work when hooked up out of the car) for a working one.
    And fitted my auto dimming mirror.
    Before
    After
    I also routed all the cables for the side mirrors to auto dim.
    Just in case I find the glass.
    Now I'm testing my TMC unit with another RNS unit to see if its working.
  30. #349
    May 2012
    RETFORD, NOTTS
    1,753
    Today I bought some tools to go steal a ford with... of course im not planning on stealing a dagenham dustbin, but I'll help you gain entry and drive yours again when you lose (or throw away out of sheer embaressment at an audi meet) your keys!
    ScottD3 likes this.
  31. #350
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    I also fixed my TMC unit.
    The fuse blow, bodged in a blade fuse for testing which worked so I updated the firmware on it.
    Time to fit it back into the car when I'm free.
  32. #351
    Jan 2011
    Aberdeenshire
    646
    The Avant is due its test at the end of the month. A quick look over found a hole in the floorpan where a rock had punctured it.
    Peeled back the carpet and out with the gas for a quick weld. I'll put it in next week and see how I get on.......
  33. #352
    jbh
    jbh's Avatar
    TDi lover
    704
    I've started stripping the engine out my old passat before the shell goes away to get turned into a trailer.
    I had a few hours at it today and its ready to drop out so tomorrow will see it sitting on the floor.
  34. #353
    Aug 2010
    3,135
    Well yesterday i replaced the o/s rear bearing and that was my bearing noise, but now in stead of a droning wa wa wa at motorway speeds theres a high pitched grr grr grr grr rumbling which wasnt there until after about 28 miles or so seemed to start after a sharp left hand motorway bend, looks like il be in the workshop again just when i thought id cured it.
    at least ive fixed my abs fault pulled the shaft and reluctor was fine, bought a replacement of ebay for £1.20 delivered so have a spare if one decides to go there was a bit of crap in the reluctor so cleaned that out my clicking noise was the dust shield catching the disc luckily not the pad surface just the hub of the disc, so i removed the sensor all was ok no damage so adjusted the sensor correctly (think i may of disturb it) clear the fault and shes pulsing pedal and abs light free just need to sort this bearing noise out now lol
  35. #354
    Feb 2013
    huntingdon cambridgeshire uk
    42
    fitted driver side outer cv boot and replacement hd meyle lower track control arm no clonking or wandering all over road now
    1999 a4 1.9 avg tdi saloon
  36. #355
    Oct 2008
    Glasgow
    431
    Finally got the chance to fit my 034 gearbox mounts and apikol carrier bushes. Next on the list is my new 034 arb and brackets, then its some rs6 egt sensors, new map and heading for the 700bhp barrier :-)
  37. #356
    May 2012
    RETFORD, NOTTS
    1,753
    Today i went back to the garage i bought my car from a year ago, they now want to take advantage of my key programming services, result!
  38. #357
    jcb
    Sep 2005
    uk
    4,077
    today I will mostly be stripping anything of value of my beloved tqs.......
    much easier stripping than it was putting the bloody bits on!!
  39. #358
    May 2012
    RETFORD, NOTTS
    1,753
    Today im going to be knocking on aprox 50 peoples door and making there life a misery :D
    I love my job.
  40. #359
    Aug 2010
    3,135
    Not today but yesterday i worked through my dinner to finish at 4:30 to pull the car back in the workshop to tackle my bearing noise so i got another bearing sent out to our parts department under warranty, pulled the o/s/r upright pressed the new/old bearing out and pressed the replacement in built it back up and its rumble/waa waa free to top it off on the way to work this morning went to put my drink in the cup holder and what ya know its fubar again lol so i think i may pop a bit of tiger seal on the coil spring to bodge it lol oh and stop it poping off
    and ive also just paid deposit to JCB for my replacement gearbox to cure my whining/notchy 1st/2nd syncro as it sounds horrendous at idle if you rev it !!
  41. #360
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Today I fitted a new stumpy ish aerial. The lack of an aerial started to annoy me but the longer ones annoy me just as much. This one is not too bad.
    Also got my TMC unit in and working. This was also one of the reasons for having a working aerial.
    I just need to try and change the source of the TMC and it should be fine.
  1. Well folks, what have you just had???
    By C_Audiboy in forum Jokes, Games & Humour
    Last Post: 18th November 2013, 22:56
  2. 1.8t air box modifications, what have you done?
    By Markeyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2011, 20:56
  3. What mods have you done to your car/engine?
    By K7ERG in forum Other Brands & Models
    Last Post: 1st October 2007, 19:50
  4. facelift headlight upgrade, what have you used to fill the gap?
    By dubmas in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2007, 13:48
  5. ...And what have you done today???
    By Justincredible in forum Photography & The Digital Darkroom
    Last Post: 7th July 2007, 18:27
