AH FabricationsSky Insurance
Page 6 of 22 FirstFirst 1234567891011121316 ... LastLast
Results 201 to 240 of 852
Like Tree96Likes
Thread: What have you done today?
  1. #201
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Re: What have you done today?
    Quote Originally Posted by griswold View Post
    Typical just ordered it! got a mate at audi to order the black washer cap.
    The black washer cap is to small for the B5.
    If it's the one from the older Audi. It only fits the TT.
    Quote Originally Posted by Bradderz_1988 View Post
    Black washer cap ??? Off what model ?? The B7 has the black power steering cap and bottle (not sure which model) but just dont no if its compatible with the B5 the cap should be just would like to fit both of them !!
    The black power steering cap failed when I ordered one. Turned out go be green.
    So I plasti dipped it. Lol
    Quote Originally Posted by @udi A3 View Post
    Today i put all my problems aside and went on the hunt for bits and bobs.
    Now have a working cup holder, 312 carriers to fit, bigger washer bottle ready to retrofit headlight washers, vented s3 wheelarch liner to aid air flow to the intercooler, and a piano black cubby hole and hazard trim panel!
    Today was a good day!
    Busy busy man.
    The vented wheel arches should help with the 312.
    Quote Originally Posted by Arrkon View Post
    Replaced the rear axle bushes with the gracious help of Byzan
    one down side is that I can now hear that one of the rear bearings is really noisy...
    will it never end....
    Gutted mate.
    you got the bearings and discs together like me?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  3. #202
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,644
    Quote Originally Posted by ScottB5 View Post
    Gutted mate.
    Indeed debating on doing the pair, as one wasn't adjusted properly so dare say I have shortened the life of that one too...
    Currently rolling in a SKODA!!!
  4. #203
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Mk3 golf power steering cap looks promising scott !!!!!
    VW GOLF MK3 1993-1998 POWER STEERING FLUID ENGINE CAP BLACK | eBay
  5. #204
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Do it.
    Do them all.
  6. #205
    Aug 2010
    3,138
  7. #206
    Arrkon's Avatar
    Oct 2010
    1,644
    Do it.
    Do them all.
    Fronts are still good, no issues there as I replaced them when I did the arms.
    Oh and on a side note. Manged to figure out what the little toggle was hanging off my handbrake grip...
    Lets just say the grip stays put now :D
  8. #207
    Jan 2013
    Darlington
    44
    Just swapped my golf for a b5. Due to needing a bigger boot. So just got thermostat sorted cv joint done. And got some coilovers,badgless grill headlights, bonnet bra, headunit, surround for new unit, exhaust on its way. Just looking for some wheels. Set of 18s so i can slam it and then shot some spacers on back. Then after tht rear discs and pads front manifold gasket and one for down pipe and imduction kit. Or and slight rust on wing to sort. Nxt few months im guna be busy and skint.
  9. #208
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Ooo nice.
    I'm sticking with my Plasti dip.
    I had enough of buying caps lol
    Haha.
    Muppet.
  10. #209
    Arrkon's Avatar
    Oct 2010
    1,644
    Haha.
    Muppet.
  11. #210
    Jan 2011
    Aberdeenshire
    646
    After posting on Bradderz TQS bearing thread, I thought I'd post an update on my doings up here.......
    So, since Christmas, I have changed a rear wheel bearing on my saloon - OEM removed, probably original at 129,000ish miles - not bad - and a FAG from All German!
    Mrs PaulFs' Avant has has a rear and a front done - AGAIN!!! The rear was about 15,000 miles old and let go (very wobbly, hub and shaft not damaged), so it needed to be done there and then. Unfortunately I had to get a First Line part - we'll see how it lasts. The front was done about 20,000 miles ago, and was howling like a moany woman. I've fitted a FAG from All German, so it should outlast the car now.
    I've also been doing more turbo adjustments on the Avant - I'm trying to get figures together for a 'How to' for the stop screw and actuator rod. It's been hard though as you have to run at 3000-4000 RPM in 3rd/4th gear, which is 60-80 MPH - not good in the snow and ice omn country roads!
    More sticky brake issues, again, reconditioned parts fitted within the last couple of years, so have just got up two front calipers from All German for the Avant, I'll worry about the saloon later.
    My tractor (Zetor 4WD) decided to play silly buggers and die after I had snow-ploughed the road a couple of weeks back. New fuel filters, cleaned out the diesel pump governor, checked and cleaned the diesel pump metering unit, fitted a new hand primer and blew the fuel lines and tank out.
    I now have no snow trouble in the drive!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  12. #211
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Been busy mate.
    Be interested in your how to when its done.
    I keep meaning to do logs of mine now it appears to be working and compare.
    I might do it tomorrow.
    I made my own iPod dock out of a cup holder.
    Looks like a normal B5 dash. Nothing special.
    Oooo ipod dock in the cup holder.
  13. #212
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    I've had a productive(ish) few days.
    On friday:
    Swapped the Winter tyres onto the Avant (yeh, i should have done it months ago, but didnt) for a trip to aberdeen next week. Gave both sets of wheels a really good clean while they were off.
    Been trying really hard to tidy my garage out, listing unneeded spares on ebay and junking crap, which resulted in a trip to the metal yard with 100kgs scrap metal, netting me £18.
    I spent several hours modifying the grilles on the S4 bumper on the Avant to make them fit round the intercooler pipes. This essentially involved grinding away the back of the grille until it cleared. Unfortunately i made things difficult for myself by seperating the two halves of the drivers side grille. On the passenger side i left them attached and just ground away at it until it fitted which was far more sensible.
    While tidying i came across the arm rest i got from Scott at ADI, so i set about fitting the in place of the broken one on the avant. Fairly easy job, the new one was cream and had broken "foot" so i swapped the black lid over, and fitted it to the original foot, and bolted it back together. Will toss the old broken one on ebay and no doubt someone will buy it for parts or whatever.
    Today was a bit less productive as i became glued to the couch after lunch for a bit too long...
    However i did some more tidying (my dustbins almost full to the top already i've chucked that much crap) and came across the three door strips i removed from the avant i broke, so decided to install them onto shed in place of the rotten ones that were hanging off, so its now looking a bit tidier! Just a pity i only had three, as the remaning original one now looks rubbish!
    Treated shed to an oil change, and tightened the jubilee clip on the PAS cooler that was leaking.
    Fitted a rear shock to the landrover.
    More tidying still to do though, and still a few bits to finish off with the Turbo Conversion on the Avant (which incidentally i havent written up yet!)
    TD5 Land Rover Defender build
  14. #213
    2,174
    Finished my RNS-E faceplate today, hope to get it fitted tomorrow.
    Started with an A3 faceplate
    Chopped top & bottom and added extra plastic to the sides, used a bit of humbrol model filler for the gaps & imperfections
    Finished faceplate
    HEKTOR and ScottD3 like this.
  15. #214
    2,174
    Fitted the nav today and sorted out the rest of the installation, but the first thing to get sorted out my faulty DIS so set to yesterday evening, got a unit a few weeks back off ebay for £25. They are a bit of a bugger to solder but looks so much better as I was missing around 50% of my pixels.
    MK2 RNS-E rebuilt and ready to fit.
    During the install I also fitted Bluetooth, Audi Music Interface and a Kufatec IMA.
    As the standard AMP on the B5 is rubbish, I have fitted an AMP from the later B7 platform, and have ran the front speakers to the AMP. I also have fitted the Aerial system from the B6/B7 platform, as I hate the roof aerial, so have fitted an Audi A6 shark-fin GPS/BT Antenna.
    Next to do is to replace the speakers, and sort out the CarPC project.
    ScottD3 likes this.
  16. #215
    "Stick a V8 in it!"
    15,381
    I like the ariel, whats the gen?
  17. #216
    2,174
    It's from an Audi A6 C5 model it's for Nav & BT only, so with the old Aerial remove I retrofitted the Aerial system from a B6 Avant, I know the B6 has screen printed aerial wires in the glass, So I have run wires around the blacked out edges of the glass for the side windows & rear window.
  18. #217
    Feb 2013
    southampton
    43
    man i wish i had the skills of you guys for electrics would love the nav and toys fitted in mine all i can do is service it change suspension brakes seats electrics i call a auto electrician audi is booked in with 1 on weds wont see change of £150 i guess as airbag light is on
    i drive hgv,s for a living and slowly learning about the b5
  19. #218
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    Bit late for that innit?
    Its summer soon.
    Any thing left from the B5 breaker?
    Did you keep the fog lights or remove them?
    Took you long enough to fit that lol.
    I wonder what a broken Arm rest goes for.
    I wonder what my faulty double din dash goes for.
    That's the plastic or metal ones?
    I need to new front ones.
    Might buy a set off ebay.
    This the land rover that is a long on going project?
    up yet!)
    What was you doing to it?
    a normal turbo or a uprated one?
  20. #219
    "Stick a V8 in it!"
    15,381
    Its summer soon.
    Yeh, i meant to fit them in december, but the car was off the road with its broken turbo, so i didnt bother. Then once it was back on the road the weather seemed to improve, so i didnt bother. Then it snowed, so she took mine to work (which did get its winters fitted in december) and crashed it into the gate. Then the weather got better, so i didnt bother. Then it snowed again.... (i see a pattern here :P). Given i'm going to aberdeen this weekend i figured i better fit them, if i didnt then ofcourse it would snow like mad and i'd be stranded under 20ft of the stuff. Because they're on i wont see a drop.
    Few odd bits, putting them on ebay, see my link in sig.
    Removed them unfortunately.
    Yeh, more lazyness. Dont really care tbh, i'll put it on at a 99p start and see what happens. If it doesnt sell it'll go in the bin or someone on here can have it for nowt.
    I think they're metal, they seemed bendable, but unlike the original ones they werent rusty and knackered. The ones on the car literally dissolved when i tried to remove them. I'm just annoyed that i wrecked the drivers door one trying to get it off the breaker!
    Yeh very long project. Audis seem to take up all my time and money so i've not touched it in over a year! I got the other shock fitted on Sunday, and installed the new heavy duty drag link on the front end. Then started undoing things i've already done as the balljoint on the A frame on the rear axle was all perished (its not even been on the road and it was knackered!) because i bought a really cheap chitty one. I've got a nice lemforder to replace it now. Old one needs pressed out though.
    Its a beachbuggy hybrid, 2280 compressor (Focus RS) and RS6 turbine.
  21. #220
    Jan 2011
    Aberdeenshire
    646
    That's the saloon full inspection service + air filter done.
    I've also changed the duff passenger heated washer jet for a new one, and had to change the winter tyres over a month early - hit a bloody great boulder going to Costco for the oil the other day and wrecked the wheel + tyre!
    Not happy as I expect it in my road, not on the main road at 60MPH but by the time I get another 15" wheel and new snow tyre I'll be changing over anyway. Ho hum - at least no other damage done.
    Front calipers on the Avant next, and her drivers heated jet! (both 'in stock' at home)
  22. #221
    "Stick a V8 in it!"
    15,381
    I was up your way at the weekend, visting a mate in Westhill!
    650mile round trip, Avant got a good run!
  23. #222
    Jan 2011
    Aberdeenshire
    646
    That was the Costco I was going to!!
    You should have given me a shout!
  24. #223
    Feb 2013
    southampton
    43
    made a booking to take mine in see why airbag light on last week took it in today to be told we dont do airbag lights so wtf on the phone they said they do god knows another none productive day oh and buckled a wheel in a faffing big pothole not a good day so far
  25. #224
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Quote Originally Posted by B5NUT View Post
    can you recomend me an ebay seller for the DIS screen?
    something i've put off doing for too long...
    that Nav install looks great BTW
    thanks!
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
  26. #225
    2,174
    will try and find the seller I used this evening.
  27. #226
    griswold's Avatar
    340
    Quote Originally Posted by les-ward View Post
    Hey les get an airbag tool of ebay they can clear the controller error that vcds cant, the cold sets mine off when really cold.
    Keep it in the glove box.
    Just done Oil and filter today, got to keep that oil clean
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
  28. #227
    Jan 2011
    Aberdeenshire
    646
    That's what I did. I must say I was surprised that it worked, although like you the light came back whenever it was cold so I just reset it each time.
    I eventually got fed up and bought another module from the scrappy, coded it with VCDS
  29. #228
    Feb 2013
    southampton
    43
  30. #229
    Jan 2011
    Aberdeenshire
    646
    I'd say no, that looks more like a scan tool.
    The one I got looked like more like this VAG VW/AUDI/SEAT/SKODA Airbag/Service Reset Tool OBD2 although I didn't get it from China!
    (I said I was surprised it worked)
  31. #230
    Feb 2013
    southampton
    43
    Quote Originally Posted by PAULF View Post
    cheers mines airbag ecu not on list but 2 are close so worth a punt it says it does others i have a 8DO 959 655 L ecu
  32. #231
    griswold's Avatar
    340
    Does list yours but that one is shipped from china though
    also this from uk
    VW / AUDI AIRBAG LIGHT System Reset Tool And Crash Data Erase Tool For The MOT | eBay
    Definately worth getting
    A6 2.4 Avant SE
  33. #232
    Feb 2013
    southampton
    43
    also this from uk
    ordered thanks all for help
  34. #233
    2,174
    Quote Originally Posted by TeKnodriver View Post
    thanks!
    The seller I used is not longer selling them. This looks exactly the same as the one I fitted. LCD Display Screen Cluster Fit Audi A3 S3 A4 S4 RS4 A6 S6 RS6 C5 Allroad Quattro | eBay
  35. #234
    Biodiesel Purrrr
    Jun 2011
    London
    150
    Nice one for the link B5NUT... might give it a go
    Did yo get any pix of the inside of console so I have an idea of what to expect from soldering point of view?
    any tips?
  36. #235
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    any tips?
  37. #236
    Aug 2010
    3,138
    Well i finally got round to replacing the steering rack for the later TQS non damper one, feels just like my old rack, now i just need to reset the tracking (ran out of time) as the steerling wheel is off centre to the other side to the other rack going to do this one day next week on my dinner the sooner the better, and im going to try sulli79's suggestion of tightening the steering rack power steering box on the rack as its got the knock/rattle when you shake the wheel with the engine off, as i had the battery off and the car was bouncing under and up to the idle speed when dipping the clutch coming to junctions its been doing this for a while but was worse today after having the battery off, ive changed the idle speed adaptation and carried out a throttle body adaptation, ive also managed to have another ****ty cheap arse ballast go on me im sick off these cheap HID kits there ok for couple of months but tend to let go very quick but thing is ive butcher'd the access caps so cant put normal H7's in or some ultra white H7's id prefer some RS4 Xenon units but there expensive as fook i also adjusted the brake light switch as the pads were grabbing before i could see the high level lit when giving it welly and constantly braking.
    oh and courtesy of Scottb5 ive sent my grill off to him to plastidip i havent got it yet but thought id show you a taster lol will post pics when fitted to.
  38. #237
    Aug 2010
    3,138
    Fitted my plastidip'd grill
  39. #238
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    That's not to bright.
    Don't know what you're moaning about.
  40. #239
    Aug 2010
    3,138
    The picture doesnt show how bright it actually is scott it could probably be seen from space lol
  41. #240
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,012
    My shed and decking has that stuff dotted all over the place.
    I no longer need a torch to see where I'm walking. lol
    Wheels in the same colour?
  1. Well folks, what have you just had???
    By C_Audiboy in forum Jokes, Games & Humour
    Last Post: 18th November 2013, 22:56
  2. 1.8t air box modifications, what have you done?
    By Markeyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2011, 20:56
  3. What mods have you done to your car/engine?
    By K7ERG in forum Other Brands & Models
    Last Post: 1st October 2007, 19:50
  4. facelift headlight upgrade, what have you used to fill the gap?
    By dubmas in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2007, 13:48
  5. ...And what have you done today???
    By Justincredible in forum Photography & The Digital Darkroom
    Last Post: 7th July 2007, 18:27
