Monster MotorsportVolks Autos
Results 1 to 23 of 23
    Jun 2004
    London
    21
    A4 1.8T Turbo Problems
    A while ago I lost all power on my 1996 A4 1.8T sport. I've had the gaskets on the turbo changed in case they were leaking but no joy. I've tried sourcing a used replacement turbo but can only find ones for a Golf 1.8T. Would the Golf model fit my A4?
    Also, does anyone know of anywhere that would do a recon/exchange turbo for a reasonable price?
    That is assuming it is the turbo - the local German car specialist garage seems to think so.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: A4 1.8T Turbo Problems
    Why don't they know where to get one.
    If you google recon turbo or look in the yellow pages there are loads of specialist ones that im sure will be able to help you.
    Jun 2004
    London
    21
    Both the mechanic and myself can only source one for a Golf. which we've been told will not fit. Been quoted 600 for a new one which is a bit more than I want to spend.
    I had a look on Google and exchange units were around 500 - still a bit over budget.
    I want to sell the car after the summer hence the lack of willing to spend money - but nobody will buy it in the states it's in.
    May 2004
    Billericay, UK
    278
    Try e-bay or someone like Turbo Technics (who will most likely repair or exchange the turbo).
    Greg.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    ok have you tried all the breakers and german ebay?
    May 2004
    Billericay, UK
    278
    And no the Golf (same as A3) model will not fit your car.
    Greg
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    imported_dumpvalve
    Check MAF.
    Turbo should be K03.
    Banging noise............?
    Jun 2004
    London
    21
    Garage have called to say it's the turbo that's at fault. It's also smoking - the car was not doing that before. They put a new oil pipe on it during the swap out and oil is pumping through it. Just one of those things I suppose.
    imported_VaulterTim
    One of those things!?
    Not at all mate, they sold you a knackered turbo by the sound of things.
    Send it back.
    Jun 2004
    London
    21
    Spoke to 4rings on Friday and they basically told me where to go. I've contacted my c/card company and they are dealing with it for me.
    Jun 2004
    London
    21
    Someone from this forum has PM'd me and is selling a KO3 turbo but it's from the 180bhp engine - mine is the 150bhp version. Does anyone know if this will fit?
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    if its from the 180bhp version it will be the K03s (sport) it will be a straight swap.
    thats what i used to have
    Jun 2004
    London
    21
    Will this swap require any ECU changes or will the car just run as it should - I assume still at 150bhp.
    Thanks for everyone's help by the way.
    Jun 2004
    London
    21
    Cananyone help me on this? I need to give an answer tomorrow. Thanks!!!
    May 2004
    Billericay, UK
    278
    As far as I know it will run on standard software but is unlikely to give any more power without a rechip - there are people on here better qualified to answer the question though.
    Would suggest talking to someone like AMD if you don't get an answer in time - one of the reputable tuners will definately be able to confirm.
    Greg
    simon_golf_tt's Avatar
    May 2004
    Fife, Scotland
    247
    I put a K03s on my old B5 when the turbo died and it worked fine. The car was remapped for the K03 and it drove exactly the same with the K03s - so it should be a straight swap.
    Jun 2004
    London
    21
    Great! Had the KO3s installed and got the car back today. Had to wait a bit as the garage had staff on holiday. All seems to work fine apart from a bit of smoke from the exhaust. Is this expected and will it go in time? The car was running for about 6k miles with the turbo broken (bad idea but money was tight!).
    imported_VaulterTim
    Did you have any joy getting your money back for the knackered turbo you were sold?
    Jun 2004
    London
    21
    4rings said "no it was working" but the garage checked it and part of the spindle had broken or something. I paid for it by c/card so they are dealing with it for me now.
    Anyone got any ideas about the smoking from the exhaust? Maybe it just needs a good run. Great to have some power back.
    I might get it re-mapped to make the most of the KO3s.
    imported_VaulterTim
    Poly,
    The smoke could be any number fo things... very difficult to say.
    Was the KO3s properly checked out before you had it installed? Was there any movement in the shaft? Did you have any smoke before? It could be your engine and not the turbo... best to ask the garage to service the car fully and do an inspection.
    T
    Jun 2004
    London
    21
    Gave the car a bit of a run and the smoke seems to have gone. The garage did suggest changing the oil in a few weeks to flush the engine.
    It's a bit jerky but it's getting better.
    Now I need some decent wheels. Do I need to lower the car if I put 17" or 18" rims on it?
    imported_VaulterTim
    No, but it would look better [img]/ubbthreads/images/graemlins/wink.gif[/img]
