Badger5Sky Insurance
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    EGR Valve removed
    Bout a year or so ago I removed my EGR pipe and blanked off the EGR vavle and the exhaust.
    During that time the EGR valve blank would all ways have a small amount of oil on it.
    It looked like the blank and the EGR was leaking. I replaced the gasket and it never made a difference.
    I got a blank made up and removed the EGR valve so it was blanked at the inlet manifold, replaced the gasket and it is still leaking.
    I read on here before that this is common and happens.
    But why?
    Is there any way to stop it from happening?
    I blanked off the pipe that was going to the EGR valve but want to remove it and any other pipe work that is no longer needed.
    Can this be done?
    Can I remove the EGR solinoid with out having errors appear on the DIS or VCDS?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Presumably its under boost pressure, and your blank isnt flat or sturdy enough to form a good seal?
    EGR solenoid can probably be removed, if you get a fault code then you'll probably get away with adding a resistor to emulate the presence of the solenoid coil.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    The blank is flat and very thick.
    Slap some Liquid Sealent on it I think. Which is a shame, I don't like the stuff.
  1. EGR valve removal
    By Glyn E in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2012, 19:57
  2. EGR and anti shudder valve removed and cleaned. Coated!!
    By Wats-on in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 21:44
  3. Removing EGR valve
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2010, 08:05
  4. Blanking plate for EGR valve. Does it work wonders
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2004, 15:12
  5. EGR valve
    By Pookie in forum Diesel forum
    Last Post: 29th July 2003, 16:11
