Monster MotorsportChris Nott
    Jun 2012
    148
    Standard Bose system
    Without having to remove it, does the standard Bose system head unit have the capabilties to add a sub. I was contemplating it but want to keep the interior and oem so avoid changing head unit. Or is it a possibility to upgrade to a later model?
    Thanks in advanced
    Jul 2007
    London
    3,250
    What do you have saloon or estate ? The estate has a active sub built in the boot side, behind the trim panel and on the saloon there's 2 free air subs on the parcel shelves...
    FOR SALE:
    Jun 2012
    148
    Interesting, saloon
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    as above. Saloon has 6 speakers, the four door speakers are normal full range units, and the two on the parcel shelf are subwoofers. Not particularly great subwoofers mind.
    If you wanted to add your own, you could always disconnect the parcelshelf speakers, and tap into the line level signals on the appropriate wires at the bose amp for your own amplifier.
    TD5 Land Rover Defender build
    Jun 2012
    148
    That's good to know that the wiring is present, thank you
  1. Upgrade standard sound system to Bose?
    By woohoo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2009, 18:00
  2. bose system
    By bainsyboy in forum TT/TT-S/TT-RS Forum
    Last Post: 19th October 2005, 23:19
  3. Bose system owners...
    By imported_Skywalker in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2005, 17:09
  4. Changing the Headunit on a Bose system
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2005, 15:28
  5. Complety changing a BOSE system....
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2004, 17:58
