Sky InsuranceJMB Retrofits
Like Tree1Likes
  • 1 Post By PAULF
Thread: Rear bushes Q on S4
    Apr 2006
    A, A
    269
    Rear bushes Q on S4
    Changed the bushes all round on my car but one of the bolt snapped and it's the one that adjusts for the tracking. Name of bolt please (has washer built on to it)
    Jan 2011
    Aberdeenshire
    646
    Call Audi and explain what one you want.
    Part numbers for 2000 2.5TDI Quattro, but should be the same for yours.
    8A0 501 387 D Eccentric bolt (Upper) or 8A0 501 387 C Eccentric bolt (Lower)
    Get the eccentric washer too. 8A0 501 385 (upper) 8A0 501 385 A (lower)
    The lower one through the hub is for camber, the one through the top control arm is for toe.
    If you haven't changed/removed the ones through the top control arm, get them too and replace them. They will need to move for the four wheel alignment, and most likely will be seized. I had a bugger of a ob getting my rear control arms out due to the top bolt being seized solid.
    adidasandy likes this.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Apr 2006
    A, A
    269
    Thanks Paulf
  1. S3 rear bushes
    By omegadirective in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2009, 09:19
  2. a3 rear bushes
    By madluke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2009, 12:40
  3. S4 rear bushes
    By CraigG in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st September 2008, 18:05
  4. rear bush replacement
    By spleenboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2006, 22:45
  5. Differences after rear bushes are replaced?
    By jbw in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2005, 15:42
