Rear bushes Q on S4
adidasandy
A, A
Changed the bushes all round on my car but one of the bolt snapped and it's the one that adjusts for the tracking. Name of bolt please (has washer built on to it)
Call Audi and explain what one you want.
Part numbers for 2000 2.5TDI Quattro, but should be the same for yours.
8A0 501 387 D Eccentric bolt (Upper) or 8A0 501 387 C Eccentric bolt (Lower)
Get the eccentric washer too. 8A0 501 385 (upper) 8A0 501 385 A (lower)
The lower one through the hub is for camber, the one through the top control arm is for toe.
If you haven't changed/removed the ones through the top control arm, get them too and replace them. They will need to move for the four wheel alignment, and most likely will be seized. I had a ****** of a ob getting my rear control arms out due to the top bolt being seized solid.
Reactions: adidasandy
905
737
