JMB RetrofitsChris Nott
Thread: A4 Headlights
    Jun 2003
    World of my own
    9,813
    A4 Headlights
    Anyone know if there is a Xenon (clear lens) replacement headlight available for 1997 A4?
    Hella don't seem to do one.
    Feb 2003
    Lincolnshire/Bournemouth
    739
    Re: A4 Headlights
    order the ones from the 1998 S4, or alternatively you can fit the later headlights with a bit of modification. It's very easy to do.
    London/Essex
    12
    Re: A4 Headlights
    Hi m8! yes as suggested you could either get the 1998 S4 xenons which are a tw0 piece version or fit in the one piece set but with modification. The modification involves cutting a little bit of metal! [img]/ubbthreads/images/graemlins/idea.gif[/img]. there is a metal lip about 1.5cm where the front indicator lens sits...you need to remove this so that you can fit in the one-piece. The wiring (if you can get hold of the original wire loom is the same! colour so that pee easy...but i couldn't connect the level adjustment as it was controlled by the rear suspension on the S4) I did this modification a couple of years back. Got the lights second hand off allaudi..for about 330 then.
    I believe In Pro do a two piece projector headlamp but i don't think that is xenon.
    here's mine:
    Jun 2003
    World of my own
    9,813
    Re: A4 Headlights
    Thanks for the advice. Like the RS grille by the way. Looking Good!
