AH FabricationsJMB Retrofits
Thread: spring stifness
    May 2011
    lancashire
    22
    spring stifness
    Hi guys , this might be a silly question but are all lowering springs the same stiffness , ie are 20mm-30mm springs same stiffness as 40mm-50mm , cheers guys...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    as a very rough rule, the lower you go, the stiffer they need to be.
    Different brands tend to be stiffer/softer as well though.
    TD5 Land Rover Defender build
    May 2011
    lancashire
    22
    I suppose the cheaper they are the harder and crashier ( probably not even a word ) it will be , cheers , prob going to go 30 on front ,25 on back on std shocks for now . Just to get front bit lower.probably going to put std 16" speedlines back on to get rid of some harshness , theyre painted gun metal grey so look ok I think , ..
    "Stick a V8 in it!"
    15,388
    not always.
    H&R for instance are fairly dear, but are known for having a fairly harsh/stiff ride.
    On the other hand Eibachs Pro-kits are known for excellent ride quality.
    May 2011
    lancashire
    22
    Suppose will have to do it and hope for the best. : )
  1. Best Shocks That Match H&R Springs
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2003, 22:38
  2. FAO 50mm H&R springs
    By V1RDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2003, 13:08
  3. What lowering springs?
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2003, 21:58
  4. Best Match Shocks For H&R Springs
    By XXX_18T in forum TT/TT-S/TT-RS Forum
    Last Post: 29th May 2003, 15:29
  5. Eibach Springs on A3 T Sport
    By paul_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:18
