Monster MotorsportChris Nott
Results 1 to 8 of 8
    AudiA4B596's Avatar
    Jun 2012
    39
    Dashboard battery indicator cable?
    Does anyone know what colour the Dashboard battery indicator cable is?
    I need to wire it to my RCL module for remote start....
    Ive hooked up the rest of the cables and the remote start works but continues to try to start the engine even though it has already started, i believe this wire needs to be connected to tell the module the car has started now and there is a note on the wiring diagram that says this wire is very important and MUST be connected to the battery indicator lamp(cable) on the dashboard. The module attempts to start the car five times (I can hear the starter motor each time), and even though already started when it gets to the end of the fifth try the car dies (alarm has also gone off a couple of times) ... :S
    If anyone knows please could you tell me, many thanks
    - Audi A4 (B5) Avant 1.8T 1996 (Dark Green)
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    B5 A4/S4 Instrument Cluster Pin Outs
    May be of help to you
    Currently rolling in a SKODA!!!
    AudiA4B596's Avatar
    Jun 2012
    39
    Thanks for that, thinking maybe its pin 14 on the blue plug, does that make sense?
    Think I'm going to take the instrument cluster completly to bits after work today and try to trace it for sure, but im not sure if thats possible..???
    I think I need an expert?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,912
    6 - Terminal 61 is the feed from the alternator diode pack
    TD5 Land Rover Defender build
    AudiA4B596's Avatar
    Jun 2012
    39
    Thanks Aragorn, once again, you are my man, shall try that now and let you know how i get on......
    Sep 2011
    Sunny Bangor. N.Wales.
    287
    what about oil pressure light
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    "Stick a V8 in it!"
    14,912
    The oil switch is a switch to ground, whereas the battery warning light provides a 12v feed with the alternator producing output.
    The oil switch also wont always latch on at idle with a hot engine. It switches at 1.5bar or so on turbo models, but you'll often see 1bar or less at idle on a hot engine.
    AudiA4B596's Avatar
    Jun 2012
    39
    Aragorn, you was right again, it was the last wire i needed to connect to get my remote start, and now i have it working really well, thanks Aragorn, you are the expert!!!
  1. Brake wear indicator cable
    By owdgit in forum Parts Requests
    Last Post: 21st July 2010, 13:11
  2. Electrics problem (alternator to battery cable name?)
    By jonnytopman in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2009, 12:54
  3. Cables on right hand side of battery
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2008, 16:11
  4. Dashboard warning indicator.
    By Jack829 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2006, 21:33
  5. power cable to battery help
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th July 2006, 21:21
