Volks AutosChris Nott
Thread: Air Con drain
    Jan 2011
    Aberdeenshire
    646
    Air Con drain
    I'm looking to clear out the Air Con drain on the Avant in the next couple of days (wet carpet, smelly, plenums fine).
    Does anybody have pics of where it is from underneath? I've found a couple of write-ups, but they talk about going from inside.
    I'm hoping to poke about from underneath, but as my cars are so mud-filled, I probably wont see the outlet!
    I can see this turning into a Wile E Coyote hose type moment!!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Aug 2010
    1,540
    the drain comes out behind the heat shields up the side of the transmission tunnel. id bob the center console out, much easier and a nicer job than crawling about under the car imo.
    Jan 2011
    Aberdeenshire
    646
    Thanks,
    I was hoping to avoid taking out the carpet, but I have just found a hole in the passenger floorpan where a rock has punched through.
    MOT tomorrow, so I'll be uprooting the carpet for welding
    Jan 2011
    Aberdeenshire
    646
    For Info
    If you take out the glove box and lower side trim, remove the door sill trim, peel back the carpet and you can just get to the drain in the footwell without having to take out the console.
    Remove the 8mm head screw holding the plastic drain and move it out of the way
    A bit of rod pokes it through no problem.
    (Was also enough for welding the floor )
  1. Drain point for air con condense
    By jetskijimmy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th January 2012, 18:51
  2. Air con drain pipe.
    By chewy. in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2010, 12:17
  3. 1.8 T Sport, Noisy Air-con ????
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2004, 14:23
  4. Hissing Air con A4 1.8 T
    By hendyc04 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2004, 18:46
  5. Air con cleaner???
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 13:56
