Chris NottAH Fabrications
    Jun 2006
    17
    Not stricktly B5, more a VAGCOM question...
    I've got VAGCOM for the S4.
    Father in law in having trouble with his VW Bora auto-locking. It's done it with his keys in the car!
    Was wondering if any of you knowlegable lot know how to disable this "feature" with VAGCOM?
    cheers
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,116
    The only time it should auto lock is over 15mph, to remove just do the opposite off this
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So if its set to auto lock -32 instead of adding it keep the original coding handy just incase.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    The only other time i know of that it will auto lock is if you unlock the car with the fob and then dont open any of the doors within a few minutes.
    If thats the case, the only way you could lock the keys inside the car is if one of the door microswitches is faulty, allowing you to open the door and put the keys inside, without the CL pump realising the door has been opened.
    TD5 Land Rover Defender build
  1. New Turbo... or not to turbo, that is my question
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2006, 15:20
  2. More service reset questions...!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2006, 22:07
  3. DIS or not to DIS this is THE question
    By imported_G4JSG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd September 2004, 12:55
  4. Evo or not to Evo that is the question
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2004, 12:12
  5. Chip or not to chip...that is the question...
    By jugman99 in forum A8/S8 forum
    Last Post: 22nd December 2003, 23:57
