JMB RetrofitsSky Insurance
Results 1 to 8 of 8
    duane's Avatar
    May 2004
    uk
    142
    Possible power loss
    My car came back from it's service today, when they did a diagnostic check it came up with the following code: (17963) charge pressure-upper limit exceeded-engine.
    My car has been re-mapped by A.M.D. The point i'm getting at is that since getting my car back today, it doesn't seem to have the same pick up/boost as it did before it went in!!! Would them sorting out the code possibly have done something to the re-map, or is it just me being paranoid [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    AndyC's Avatar
    Apr 2003
    Dorset
    717
    Re: Possible power loss
    should not have changed it, unless they reflashed the ecu and wiped the map!
    duane's Avatar
    May 2004
    uk
    142
    I phoned A.M.D today and they said that it would not have anything to do with the re-map.
    They say that it could be a split hose,diverter valves, or Maf.
    If it was the maf wouldn't it have come up with a different code? I don't think it is the maf for some reason. I'm thinking more air/boost leak???
    Does anybody know anywhere closer to Leicester than A.M.D in Oxford, i could take it to get it checked out and tested.
    The Audi specialist i go to doesn't have a pressure tester. So i asked how he would check for leaks etc.. he said diagnostics check and looking and listening. Without sounding dumb- would that be enough to find a split hose or diverter problem???
    Any help appreciated,
    Thanks, D. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Mar 2004
    Leicester UK
    133
    What audi specialist do you use in or around leicester then????
    duane's Avatar
    May 2004
    uk
    142
    I use the lion garage !!! Do you know somewhere else in leicester that is an audi specialist?
    liongarage.co.uk
    Jul 2005
    2,488
    hmm, not quite as far, but you could try jabbasport just down the a47 in peterborough.
    duane's Avatar
    May 2004
    uk
    142
    Do you know what their hourly rate is? Do they have a web site? I've tried looking it up but can not find anything!!!
    Jul 2005
    2,488
    http://www.jabbasport.com/
    heard lots of good things from other dub owners.
