EM TuningSky Insurance
Results 1 to 10 of 10
    griswold's Avatar
    336
    TQS judder/misfire
    Been having a a juddering for a second or two under heavy throttle, ease off and ok will judder with .5 bar but will go to 1 bar
    it happens at various speeds and revs.
    When its cold it dosn't happen straight away had full boost and no juddering and car went like a rocket
    after a couple of miles started to happen when warmed up.
    Waiting to get a pressure test for leaks, checked for visable and tightend hoses.
    Changed vac line, diverter valve, put new air mass sensor, coolant temp sender,fuel filter
    nothing when scanned.
    Think of getting a set of coils? ignition control module?
    car seems fine when cold? car 1.8 tqs remapped
    Ideas as to why fine cold ?
    thanks
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    Check the Plugs they maybe arcing does it do it at idle at any point ???
    Had similar fault with mine was intermittant then after driving it a bit more it dropped a cylinder permanantly so disconnected the coils one by one and number two had dropped swapped the coil to a differant cylinder and it moved to that cylinder so swapped the coil for a good one and was fine after that.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    griswold's Avatar
    336
    Changed the plugs forgot to put that in first post.
    Did that show up when scanning your dropped cylinder?
    A6 2.4 Avant SE
    Chriscooke's Avatar
    Clueless!
    Mar 2012
    Taunton
    381
    Did you change the plugs before or after the problem started? Could be a loose plug.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,941
    Airleak?
    Mums A4 was doing exactly this, and it was a split hose on the inlet manifold.
    TD5 Land Rover Defender build
    griswold's Avatar
    336
    Yes the problem started after plug change but thats when i noticed it.
    Probably a coincidence?
    Changed them for another set too.
    I'm thinking airleak but its fine when cold?
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    14,941
    hers seemed better when cold too, got worse when it was hot.
    It was fairly random, mostly occurred at medium to large throttle openings between 2-3k or so. If you got it upto ~4k and gave it full throttle it would often take off at full boost with no trouble, which should have been the tell tale that it wasnt ignition related. I didnt find the airleak until after swapping everything ignition related, and the MAF though.
    Was one of the small bore hoses that goes to the tank vent valve or something, had split underneath and you couldnt really see it.
    griswold's Avatar
    336
    Thanks, i was hoping the hot/cold running would help identify the problem.
    Maybe as the engine heats up the pipes warm up and the leak is worse.
    Would be great if it was just a leak and i could find it.
    Aragorn would be great if you could help identify the pipe or location where you had the split
    A6 2.4 Avant SE
    "Stick a V8 in it!"
    14,941
    to the right of the throttle body a hose comes off then turns 90degrees and snakes off to either the bulkhead or breather thing (cant mind which)
    It was that hose that was split.
    griswold's Avatar
    336
    Just fitted new coils x4 problem gone:D
    A6 2.4 Avant SE
  1. A4 1.9 TDI pd 130 misfire - cough/mis/splutter under load - judder on idle
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2012, 20:09
  2. 1.8 TQS BAD judder!!!
    By Gops in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th September 2011, 23:52
  3. Judder/Misfire @ 1400rpm
    By sarah1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2010, 19:20
  4. A3 2.0 TDI 54 plate judder/misfire
    By ayrton senna in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2010, 17:26
  5. juddering / misfire
    By amb276s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2005, 23:55
