JMB RetrofitsAH Fabrications
Results 1 to 26 of 26
    30
    Smile Aircon Fixing Help & Exhaust/Engine Advice Needed Please!
    Have been trying to sort out a few problems with my AEB B5 2001 A4 Avant (1.8SE) (just gone over 100k miles) - Have cleared the SRS light, but that's another story!
    Anyhoo, aircon hasn't really ever blown cold air and we're going to driving through France in July/August and I want to get it sorted! It has been gassed not long ago and I'm pretty happy that it's not a problem. Also the ECON light comes on and off with the switch as it should do.
    I have run the codes on the unit using the recirculate & up arrow, and whilst C1 has returned a 0, I have a number of errors on the following: -
    C32 - 219
    C33 - 178
    C34 - 37
    C35 - 24
    According the lists, these are respectively, temp flap, A/c flap, Fuss/Def flap and ram air flaps.
    Question is - where do I find all of these to clean? Is this likely to help or maybe indicative of another problem?
    The aircon pump was changed 2 years ago - not sure if any of the other components were changed.
    Any advice/pointers gratefully received!
    The other issue I think is either exhaust or engine mount related. I had to replace the downpipe & CAT prior to the MOT. The type I have has the flexipipe, CAT and EGT sensor all in the same piece. I replaced this using a new proper sleeve, but since then, I get a vibration/knocking when turning left - particularly on roundabouts. It's definitely exhaust banging and and nothing else. Just wondering if it's something I've missed on refitting that section of exhaust (rest of system was left in place) or if I have engine/gearbox mounts that are on their way out.
    Right, over you lot who know! Thanks in advance.
    Darren
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    I've no idea to be honest.
    But have you checks the flap motors are plugged in?
    Do you have a copy of VCDS?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    If the error counters are static then there probably isnt any problem. If there is an issue they'll be all over the place, jumping around.
    Is the compressor actually engaging?
    TD5 Land Rover Defender build
    Aug 2010
    1,540
    while its ticking over with the aircon on. feel the pipes under the bonnet..... are they ice cold? if the pumps working, its gassed and the high/low pressure switch is ok then they should be.
    if they are then it may well be a flap problem not directing air thru the cold bit in the heater box......
    take the glove box and lower cover down from the drivers side. look for the motors..........
    then while looking, press each of the buttons to operate the motors/temperature/flaps.
    do they all seem to move in turn when certain buttons are pressed?
    is there one not working/moving? unbolt the motor but dont unplug it.... then move the flap lever yourself? can you get the air coming out of the vents colder by moving the flap lever into certain positions?
    "Stick a V8 in it!"
    15,350
    I'm pretty sure all the air passes over the evaporator, theres no path around it.
    The blend flaps just control how much air passes over the heater matrix.
    30
    Hi Scott - I haven't unplugged them, so I guess they're plugged in? I'll have to get a copy of the workshop manual and see where they are - is it a fairly easy job to get to them?
    I have VCDS lite, but I'm getting connection errors with the software - it will connect but reading faults is a problem. Poss that the anti-virus software is getting in the way - just got to figure out a way to disable it!
    Darren
    30
    Hi Aragorn,
    Yep, the figures are all static and compressor is engaging. I know my old Man had a similar problem with the aircon on is A6 Allroad, and apparently there's a diverter valve that sticks, but his is an '05 and apparently a different system. Don't particularly want to have to strip the whole system out, check clean and put back in if I can help it, but I need to get it sorted or the family and I are gonna fry in France!
    Darren
    30
    Hi Murran,
    That certainly makes sense - I'll do that then and see where we are. Can't work on it tomorrow as off to Santa Pod for the race retro in the Montecarlo - come over and say hi if you're there - I'm on the BetaBoyz stand.
    I'll report back my findings.
    Darren
    Quote Originally Posted by murran View Post
    30
    If that's the case, then maybe there's a flap or valve that just isn't working?
    Darren
    "Stick a V8 in it!"
    15,350
    Forgetting about the AC, does it correctly shift from "cool/ambient" to "hot" if you adjust the temperature up and down? If so, the blend flaps are fine.
    If so, i'd see about having the system regassed, and perhaps the dryer replaced. A decent company will do a leak check as well.
    If the blend flap motors were faulty you'd see those error counters jumping all over the place. I had a faulty temperature flap motor, and when driving the air from the vents was constantly changing from cool to hot and back to cool.
    Aug 2010
    1,540
    if you simply feel the ally pipes under the bonnet when the aircon is on..... if theyre ice cold then the problem isnt with the gassing, pump, dryer etc.
    are the pipes cold or not?
    Jun 2003
    World of my own
    9,813
    Check the aircon rad fan is kicking in as well. It's the one at the back of the main radiator. They are a common failure and a cheap and easy fix, about £80 from GSF.
    Alex Turner
    30
    Hi Aragorn,
    I thought that those C numbers were error counts rather than values? Anyway, yes it does heat the car, so maybe you're right on the flaps and holding on to the pipes is a lot easier than pulling panels off - I'll check later when the car is back and report back.
    Is there anything else that should be changed at the same time as the dryer? Presumably that's a DIY fit or should it be done by a specialist? There seem to be wildly different pricing for these things - AP Lockheed being cheap to OE expensive. More than happy with AP's brake calipers, so assume that rest of the equipment is ok?
    Darren
    30
    Will check and report back - meant to do it yesterday, but didn't get back from Santa Pod til late and then just needed a beer!
    Darren
    30
    Hi AndyMac,
    Thanks for the input - will the fan come on as soon as the AC is on? I'll turn the temp down to 'Lo' and see what everything is doing.
    Aren't there 2 fans on the rad?
    Darren
    Quote Originally Posted by AndyMac View Post
    "Stick a V8 in it!"
    15,350
    Theres one fan driven by the engine that runs all the time, and another electric one that should come on with the AC.
    30
    Thanks Aragorn - will report back
    Darren
    30
    Right, update time.
    Just been out (in the rain!) to see where we are. Engine running, stat set to 'Lo' - both fans running. Pipes are not getting chilled, so I'm guessing that when the pump was replaced, they didn't change the dryer. Can I change the dryer and then go get the system leak tested/regassed, or is it something that can only be tackled by an aircon specialist?
    Thanks guys and look forward to hearing from you!
    Darren
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by LanciaNut69 View Post
    Right, update time.
    Darren
    The dryer is easy.
    remove both pipes, remove dryer and reattach.
    I'd replace the seals as well though.
    Make sure the system is degassed before you do it.
    You don't want a face of the stuff. Its not nice. trust me
    30
    Thanks Scott - can see dryers on ebay - any recommendation AP Lockheed or other?
    This looks too good to be true - AUDI A4,A6,80 ,100 AIR CONDITIONING DRYER TSP0175282 | eBay
    This AIR CONDITIONING RECEIVER DRYER for Audi | eBay or this AUDI A4 RECEIVER/DRYER/AIR CONDITIONING | eBay seem more on the money, or is the Lockheed one ok.
    No mention of seals though - dealer part only?
    Thanks for the pointers on fitting.
    Darren
    Quote Originally Posted by ScottB5 View Post
    The dryer is easy.
    Aug 2010
    1,540
    is it definatly gassed? does the pump cut in? ie the clutch on the front of the pulley is going round (not just the bit the belt works on)? might be as simple as a broken wire to the clutch.
    "Stick a V8 in it!"
    15,350
    I'd get an AC specialist to change the drier and regas as the same time if you go down that route.
    30
    Hi Murran, pump definitely cuts in and out when the aircon is set to low, as does the electric fan. Clutch is working properly too. Assume that it's gassed as ECON light goes on and off on the button.
    30
    Hi Aragorn, thanks for that - maybe I'll try a few local places and get some quotes. Anyone got a recommended place in or around Newbury/Basingstoke?
    Darren
    Aug 2010
    1,540
    id go with others advice then and change the drier.
    personally ive never changed one as a cause of the system not performing. only cus of them being damaged by minor accidents or being holed by stones/corrosion etc.
    30
    Hi Murran,
    I think we're to the stage now where it's got to be checked for gas and then look at getting a quote for dryer. If it's low on gas anyway, I'll probably change the dryer meself and the get the system regassed.
    I'll keep you posted on progress.
    I did do a check check of the vents as far as I could and I can hear then move when you select the manual controls so I think we're getting near to the cause.
    Darren
    Still need some advice on the exhaust/engine mounts though please!
  1. Help - Torn Pipe/Valve advice needed
    By Ash4d in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd April 2012, 15:09
  2. HELP and Advice needed please
    By k10 in forum The Welcome Section
    Last Post: 15th January 2012, 10:30
  3. Help locating / replacing engine mounts - pics please!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2010, 20:14
  4. Hello everyone and Help! 2.6 Coupe advice needed!
    By AudiCoupeTim in forum Classic Audi Forum
    Last Post: 25th March 2007, 18:13
  5. Urgent Advice Needed Please with my Audi S3
    By lUCKYS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 12:53
