Sky InsuranceChris Nott
    Apr 2009
    west London
    35
    Facelift Tailgate diffrences
    Hi there
    after a slight (large) mishap, i will prob be in the market for an S4 Avant Tailgate and bumper(depending on what the insurance company do...)
    My question is, what are the differences between Pre and facelift models, and will a non s4 tailgate be ok??
    there's a 2000 one on ebay at the mo and it looks different around the lock panel.
    Obviously the bumper is s4 (and facelift) specific.
    Many thanks
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    Iirc the bumper will need PFL side mounting brackets if yours is facelift if yours is PFL then no worries.
    With the boot the locks are differant iirc and also the boot trim finisher around the barrel as they have switches instead of a 'pop lock barrel' and heard it can be quite tricky or even impossible to do !!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    Tailgates are specific to pfl/fl only. No difference between an S4 or A4 one bar color.
    If it looks different, its probably just a PFL one advertised incorrectly.
    The FL has a very flat grab handle, whereas the PFL grab handle is rounded and sticks out more.
    TD5 Land Rover Defender build
    Apr 2009
    west London
    35
    Thanks guys. The one i saw on ebay had no handle at all so will give that a swerve. Fairly sure the ins company will write it off, so will be on the lookout for a breaking FL avant as there's nowt wrong with the car apart from that.
    jcb
    Sep 2005
    uk
    4,077
    surely a FL boot will fit a PFL car and vice versa?
    cant believe they changed the contour of anything or the mounting/locking points
  1. Fitting S3 Tailgate onto A3 Facelift to pre Facelift...
    By Richieroo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 19:52
  2. What Audi did to facelift the B5....
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th April 2004, 01:29
  3. Definitive list of the facelift changes...?
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 13:49
  4. changing headlights and rear lights to facelift
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2004, 23:10
  5. Time for a facelift?
    By Anito in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th December 2003, 08:17
