Badger5Monster Motorsport
Results 1 to 9 of 9
    imported_mc119856
    ABS issues - still!
    A few weeks ago i posted a problem i was having - whenever braking to a standstill the ABS would cut in . After taking some useful advice, i cleaned my ABS sensors which cured that problem.
    The thing is, now the brake fault & ABS light come on. This usually happens 5mins after driving & has progressively got worse. After visiting my main dealer for some diagnostic i was told that it was showing a sporadic
    "ABS/dash panel insert electrical connection - No signal" fault (code 01203).
    Has anyone seen the fault before or can suggest what i might be facing?
    My only option given by Audi is to pay them Ł90 an hour to diagnose the fault!!!!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Re: ABS issues - still!
    Go here this will help.
    ABS
    imported_mc119856
    Thanks doc, this does sound pretty similar. I'm gonna have a go at cleaning these connectors too, but could you tell me where to find to ABS module?
    Cheers.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    I went to partfinder and hand all the breakers contact me. Make sure you have the part No and check with Audi if there is an upgraded unit for you car and what the part No is so you ave a choice of two.
    Sep 2005
    uk
    65
    i got an abs module up for grabs.... 4D0 907 379 D
    let me know if any good?
    Nov 2003
    114
    disconnct ur battery and let it sit over night, thats how i cleared my abs fault
    Oct 2003
    171
    my battery died after i had not driven the car for a month. When i first started it up i got the abs /brake fault symbol in the dis on the first couple of times i started the car after a quick charge up. After a long run in the car it seemed to go away, havent seen it since.
    imported_mc119856
    Thnaks rrr, but i'm after part no: 8E0614111A or 8E0614111M.
    I've tried searching through partfinder & other similar sites & ive only managed to source one at Ł320 delivered.
    Theres a 8E0614111AB on ebay, does anyone know if i can use this module?
    Meanwhile i'm off to diconnect my battery, let you know how that goes.....
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Check with Audi UK they will let you know.
