Chris NottAH Fabrications
Results 1 to 13 of 13
Thread: ARB Fitting
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    ARB Fitting
    I have a new front ARB for my car.
    When fitting it do i need to grease or copper ease the rubbers so that it does not squeek?
    I have never fitted on my self before?
    Cheers.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: ARB Fitting
    Are they ruber or polyurethane? Is poly, you need to use a silicone based grease... preferably a REALLY thick one that wont vanish in 5 minutes
    Rich
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: ARB Fitting
    I have not got any poly bushes, should i replace them as well then, i was just going to leave the original ones in.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: ARB Fitting
    If your replacing the ARB, i would replace everything that is in easy reach whilst its out. The rubber bushes tend to go soft and will mean the ARB will move more than is necessary. Is it an aftermarket ARB or standard replacement?
    Rich
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: ARB Fitting
    It is an aftermarket one.
    Where can i get the bushes from...
    YOU????
    ...Watching you!
    Earlsfield, London
    5,087
    Re: ARB Fitting
    What brand is it and also what size?
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: ARB Fitting
    It is eibach and don't know what size, just ordered it.
    ...Watching you!
    Earlsfield, London
    5,087
    Re: ARB Fitting
    Ok. Well it actually should come with some poly bushes as the ARB will be thicker than the OE one. That being the case, it may even come with the grease too
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: ARB Fitting
    Sweet thanks for the info mate....
    Very helpful as always...
    ...Watching you!
    Earlsfield, London
    5,087
    Re: ARB Fitting
    No problem [img]/ubbthreads/images/graemlins/ok.gif[/img]
    May 2004
    Billericay, UK
    278
    Re: ARB Fitting
    Remember to tell us if it makes much difference... [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Greg
    Danielson's Avatar
    Jun 2004
    UK
    704
    Re: ARB Fitting
    hi all, at work we use a red grease, i dunno what it is but i will find out if u want, i always end up getting covered in it while leaning on the car. f*cking god damm red [img]/ubbthreads/images/graemlins/swear.gif[/img]..........
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: ARB Fitting
    Cheers snoop mate....
    Will do Greg im hoping it will tighten up the front just a little more.
    Although now i have had my Front Arms replaced it seems to be tighter already...
    Watch this space.
