Badger5JMB Retrofits
Thread: 1.9 TDi Issues
    Oct 2008
    59
    1.9 TDi Issues
    Hi - tryed to do a search on the site but for some reason none of the thumbnails are showing which is making it hard to follow.We've got a 98 A4 1.9 TDi with nearly 160K on the clock. a couple of times recently it has been a little bit hesitant some times when accelerating, nothing too bad but noticeable all the same. there is plenty of fuel in it. This morning, it has cut out twice after being started, and the sorted itself out and seems to be running ok.Any ideas what the issue may be?Many thanks, Jamie
    A4 B5 110 TDi SE Avant
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Try blanking off the egr valve to rule it out on that sort of milage it may be heavilly clogged up.
    Oct 2008
    59
    Quote Originally Posted by Bradderz_1988 View Post
    will give that a shot, thanks. Is it relatively easy to do and woudl you able to blank it off long term?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,018
    Quote Originally Posted by G111MDS View Post
    yeah.
    Just shove a sheet of metal cut to size, drill two holes and put it between the EGR and or pipe.
    It will stop the exhaust gasses from going back in to the engine.
    Mines been blanked off for about 25k with no issues.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Oct 2008
    59
    Quote Originally Posted by ScottB5 View Post
    yeah.Just shove a sheet of metal cut to size, drill two holes and put it between the EGR and or pipe. It will stop the exhaust gasses from going back in to the engine.Mines been blanked off for about 25k with no issues.
    excellent, thank you! a job for the weekend!Cheers, Jamie
  1. My A4 TDI issues
    By Connor_scotland in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th December 2010, 16:07
  2. A4 2.5 TDI Issues
    By L4FOU in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st October 2010, 15:02
  3. Help !! v6 TDi issues
    By Neutech in forum Diesel forum
    Last Post: 9th October 2009, 17:58
  4. 2.5 tdi issues!
    By btmotorsport in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st May 2008, 20:03
  5. Clutch Issues? TDI QS with Revo....
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 13:34
