AH FabricationsEM Tuning
Results 1 to 8 of 8
    n2w
    May 2012
    11
    Electrical Issues
    Hi All i have a few issues
    Its a 99 S-reg A4 Avant 1.9tdi se manual
    My indicators have stopped working this includes hazard lights but they flash when i lock or unlock the doors.
    The temperature from the central display in the instrument panel has completely disappeared and i have not got any heating regardless of what i set the temperature too, the rest of the instrument panel displays correctly.
    I have 2 relays the 267 (A/C clutch relay) and one of the 373 relays tucked up at the back under the steering wheel these are clicking like mad
    I swapped the relays with know working ones and the faults still occur
    does anyone have any ideas.
    cheers
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,879
    Sounds as if theres a bad connection/resistance/corrosion on the heating/ac side of things.
    Is the blower motor working just cold or not at all ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,360
    Has to be water related, too many things un related to go wrong with any other fault
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    I agree with mark, too many different systems going wrong... check the seal under the ECU box, as its right above, as they do perish.
    Currently rolling in a SKODA!!!
    n2w
    May 2012
    11
    Quote Originally Posted by Bradderz_1988 View Post
    The blower works i get cold air i assume this is just outside temp, The temp display on the driver info panel has disappeared seem really random
    n2w
    May 2012
    11
    Quote Originally Posted by Der_Techniker View Post
    Where abouts is the ECU
    Aug 2010
    2,879
    Drivers side under the scuttle panel in the ecu box.
    n2w
    May 2012
    11
    Dry as a bone i will have to look else where for water
    Someone mentioned and ignition switch can cause a similar fault anyone heard of this
  1. Ongoing Alarm/electrical issues UPDATE
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2011, 13:53
  2. Electric issues
    By steady jay in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2011, 01:00
  3. More Coolant/Electrical Issues?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2011, 23:06
  4. Electrical issue !!!
    By jimiboboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2010, 14:22
  5. Electrical issues
    By Hangn69 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th February 2010, 19:36
