Monster MotorsportVolks Autos
Results 1 to 12 of 12
    May 2012
    Harrogate
    23
    Yorkshire based Diagnostic person? - Alarm playing up
    Hi,
    Wondering if there is anyone near Harrogate with access to a diagnostic cable that may exchange a fault code reading session for some beer tokens?
    My alarm is going off all the time and I have been told that reading the fault codes that it logs may help me pinpoint the root cause? I have disabled the interior sensors using the door post button but it's still happening. It also only sets (with a beep) occasionally and sometimes even once you've walked away from the vehicle. I am hoping that it is something simple like the bonnet sensor (in which case I may need a pointer as to how to locate and disable it) or maybe that my battery is on the blink but I dont want to start paying £50+ to find out that I could fix it for nowt!
    Thanks in advance to anyone that can help me!
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    I'm in Ampleforth, near Thirsk with VCDS??
    Any good?
    Dan
    2002 2.5 V6 Quattro
    May 2012
    Harrogate
    23
    Hi. That would be an easy journey for me. Could you PM me details of what sort of days/times are convenient?
    Thanks a lot fr the offer of some help! Alarm has been driving me mad all weekend
    Jun 2012
    hi
    was wondering if the problem with the alarm has been resolved as my a4 1996 is doing the same??
    May 2012
    Harrogate
    23
    Hello. Not yet. I've found that if you disable the interior sensor that it happens less. Still trying to find a way to get it on the diagnostic without it costing me 50 notes! I'll keep you informed
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Didnt you go see Dan?
    Buy youself a cheap VCDS cable, they're a tenner on ebay.
    TD5 Land Rover Defender build
    S4_dan's Avatar
    Jan 2006
    1,503
    No, Sorry, I hadn't got back to him. Started a new job last week and both kids are ill. It's been manic. I'm free most sundays if those days are any good to you Jaishaw?
    2002 2.5 V6 Quattro
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    I thought the cables from Ebay didnt work/are no good
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Jun 2012
    Scotland
    6
    The VCDS cables from ebay are fine as long as you install the correct drivers, I've been using one for ages along with the free Ross-tech VCDS Light software..
    With regards to the faulty alarm though, I think a common fault is with the actual alarm unit its self, If you open it up you might find the set of small button type batteries have leaked and started corroding the PCB inside the unit.. A friend had a similar problem with his alarm going off and we traced it to this but this did not show up any codes on vag-com..
    May 2012
    Harrogate
    23
    Cheers chaps. I think I may invest eventually. For now, I am still a bit of a novice so would prefer to have an experienced Audi owner help me out.
    Dan - Sundays are a good day for me too. I will PM you with my number so we can sort something out.
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,029
    am in Bradford, was in Harrogate last weekend just seen this post now.
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    Viking's Avatar
    Mar 2010
    208
    I'm up at Scotch Corner if you need a scan doing mate.
  1. Diagnostic tools which one and why personal experience required ?
    By Duktor in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2010, 14:41
  2. Phone based diagnostics
    By leshkin in forum General Chat
    Last Post: 24th June 2010, 00:11
  3. ABS light switch off diagnostics / in south yorkshire?
    By jakeriddler in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2007, 11:07
  4. '96 alarm playing up
    By imported_PaulA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2004, 15:30
  5. A3 Alarm
    By markp in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 15:11
