Monster MotorsportChris Nott
Results 1 to 10 of 10
Thread: Obd-Wan Kenobi
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Obd-Wan Kenobi
    Hi all, thinking about buy a OBD2 Cable, I have no faults but was wondering if there is anything I can unlock and or change lol
    What should I be buying?
    Thanks,
    Ash
    27,089
    For a B5 then I suggest you try the shareware tbh with cheap cable, if you want to use on variety of cars old & new, then the pro hex-can-usb is best option as supports them all, of which I sell.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    Tell me more, the Wife has a mk4 6n Polo, which could be cool to connect up :-)
    27,089
    Thought 6N was mk3 & 9N was mk4, maybe wrong.
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    6n is known as mk4 through the forums and most VW garages. But the true hardcore know it's correctly known as a mk3 face lift from memory.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    You can change the coding options for warning lights heres the ross tech info on what to do if you decide to
    Recode for warning lamps (through 1999 only):
    [Select]
    [17 - Instruments]
    [Recode - 07]
    Write down the existing coding for future reference.
    Enter 5-digit code from below
    [Do It!]
    Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
    00 - No available equipment
    +01 - Brakepad wear sensor warning active
    +02 - Seatbelt warning active
    +04 - Washer fluid level warning active (may only work with pre-2000 models)
    +16 - Navigation System (non-USA models)
    Look at the third digit in the coding (Market version):
    0 - "Germany" 24 hour clock
    1 - "Rest of World" 24 hour clock
    2 - "USA" 12 hour clock
    3 - "Canada" 12 hour clock
    Look at the fourth digit in the coding (Cylinders):
    4 - 4-cylinder
    6 - 6-cylinder
    Look at the fifth digit in the coding (Distance impulse multiplier):
    0 - TDI Engine (non-USA models)
    2 - Non-turbo Gasoline engine
    4 - Turbocharged engine
    So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
    its handy and useful sometimes and good to have !!
    Aug 2010
    3,135
    Oh and also locking coding
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    A4 pre-1998 with Delta radio and anti-theft system
    Standard Coding: 03468
    A4 pre-1998 with Delta radio, anti-theft system and keyless entry
    Standard Coding: 12172
    A4 1998+ with Concert/Symphony radio and anti-theft system
    Standard Coding: 03340
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
    add 03340+64+32= 03436
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Theres effectively three levels you can go with these cables.
    Basic: £10 ebay lead, free version of VCDS Lite. This will allow you to do the basics of scanning for fault codes and a few other bits, but it will only work on non-canbus cars. Can be a bit tricky to get working due to the way Windows allocates Com ports to the lead.
    Basic + Licence: £10 ebay lead plus a $99 licence for VCDS Lite, which unlocks most of the features, but still only works with non-canbus cars. Also pay close attention to the terms of the licence, as its permanently tied to one PC and is not transferable. There is also the benefit that if you choose to upgrade from this level to a genuine cable, Rosstech will give you a credit for $99 you've spent on the licence off the cost of the full kit.
    Full Genuine: £250ish for a Genuine lead, which contains the licence built in. Full featured, supported by rosstech, and works on all cars. Can also be sold on in future as the licence is part of the lead/dongle rather than tied to your own computer.
    Personally i think that most casual users with a B5 and other older cars will find the Basic option works well enough for what they need it for. Plus, its a very small expense that gets the tool in their hand and they can play with it without having to drop a large sum.
    TD5 Land Rover Defender build
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    391
    With VCDS Lite what things can you do with it though? change system settings reset service thingy and so forth
    27,089
    But the support doesnt follow the cable if its been registered & you have to pay the $99 to get support on a second hand cable.
  1. OBD Port on R32
    By FactionOne in forum Volkswagen and other VAG
    Last Post: 4th June 2005, 13:50
  2. OBD-II Port
    By FiG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2005, 20:24
  3. Skoda OBD socket
    By Khufu in forum General Technical / How To
    Last Post: 10th September 2004, 13:35
  4. obd vag com reset device
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2004, 08:15
  5. obd socket
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2003, 17:48
