Chris NottBadger5
Results 1 to 14 of 14
Thread: Break fluid
    Jun 2012
    Ireland
    59
    Break fluid
    Hi i was recently changing front brake flexy pipes and had a bit confused with brake fluid. I know its has to be dot 4 but its green colour and dot 4 is yellow ish... is that some sort of racing brake fluid?! Its 1.8 SE 98.
    Oct 2008
    Glasgow
    431
    Buy ATE racing blue. Very good fluid and is not that expensive. I run this fluid in my rs4 so it should be ok to run in your car.
    Jun 2012
    Ireland
    59
    cheers will get that for top up, when i went to few motor factors i was told to put dot 4 and it will be ok?!
    Oct 2008
    Glasgow
    431
    I would just flush the old stuff out and put fresh ATE in. I dont think mixing brake fluids is a good idea.
    Jun 2012
    Ireland
    59
    neither do i, i think mixing old stuff with new its never a good combination. I dont think u can even mix racing fluid with standart one cause its different grade and boiling point.
    Oct 2008
    Glasgow
    431
    I would say you are right.
    Jan 2011
    Aberdeenshire
    646
    I would just buy the Dot 4 stuff as per the handbook and be done with it..
    People get het up about brake fluid boiling, but a few years a ago I had a heavily modified Ford Cortina with 2.8i vented discs and Austin Princess 4 pot calipers on the front (remember THAT conversion!!) and Sierra rear discs and calipers, that I often drove down back roads to the point the discs would glow a dull red. The fluid reservoir would actually smoke and you would burn your hand on the master cylinder. At no point did I feel the effect of boiling fluid (Pedal goes down with no effect, as if full of air). I did however get severe brake fade due to the temps of the vented discs being so high (This is felt as a rock hard pedal with no braking effect). It also causes bent steering wheels as you pull like buggery to try and stop! I used Dot 3 fluid in the car.
    If you are really driving your car to the extent that DOT4 boils, and have discs and pads that will still actually stop you, then I would be VERY impressed.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,000
    No harm is going for the ATE Blue. I got that in mine when I did my brakes last month.
    Topped up with blue and bleed each calliper till the green/black stuff was gone and a nice bright blue came out.
    If you forget about racing and normal for a second, the blue colour is very good for knowing when the old brake fluid is out and the new stuff is in with out having to worry about air bubbles, air locks or any thing.
    I've boiled my brake fluid and I drive standard 1.9 TDI.
    That's the other reason for going blue over normal.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Seems excessive using ATE blue on a 1.8 SE tbh, though scotts point about the color change for bleeding is a good one, i'm not sure its worth the expense on a stock car.
    I've had my car on track and only managed to boil the fluid stood in the paddock due to heat soak. Thats completely stock brakes, road pads, and standard DOT4 from the motorfactors. They performed perfectly fine out on track, though the pads did start to exhibit fade after 5-6 hard laps.
    Whatever approach you take, make sure you empty the fluid reservoir before you add the new fluid, as mixing the new stuff and the old stuff will reduce the gains from the new fluid.
    Mixing fluid as a top up is no issue at all, they all meet DOT4 specifications for a reason!
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,000
    That depends on price really.
    I got my ATE Blue cheaper than normal Dot4. :win:
    Surly that can produce bubbles with in the system, which is what you want to avoid generally.
    So drain out as much as you can, leaving a little bit in the bottom, then top up and drain.
    Jan 2011
    Aberdeenshire
    646
    The point I was making is that it is likely that DOT4 fluid will be up to the job in all but the most extreme cases, so do you really need to fork out more on racing stuff. Obviously if you have special 'ScottB5' fluid providers, then get the higher spec as it's the right price! (As I do with my silicone grease)
    Note the higher DOT fluids are also more hygroscopic, so need changing more often. (IIRC)
    The OP says his fluid is green, so he should be able to tell when the new, wee-coloured DOT4 comes through.
    You shouldn't get bubbles as long as you don't operate the pedal whilst the reservoir is empty. It's the same when you change the reservoir after blowing it up with EeziBleed.
    Which brings on the next point:- Beware when using EeziBleed, there's a thread floating about where most of us seem to have blown up the reservoir at some point due to using more than about 10 psi when bleeding the system. I have used it successfully since - keeping the pressure down!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    ATE super blue is a doddle when bleeding just drain the old out the resivour fill it with blue then when you get a dark blue lock off the nipples jobs a good un lol
    Also its interval for changing is every 4 years instead of 2 !!!
    boost-addict's Avatar
    Aug 2011
    977
    really?
    ive never had brake boil on the road, and ive had some quick cars, very tuned r5gtt, a quick little starlet, a s13, and now a a4 1.8tqs, i brake hard and never experince those effects,
    on track how ever is a diffrent ball game, heat soak and prolonged use (compression of brake fluid) of the brakes boild the brakes as stated above. but for a stock 1.8se theres literly no point bothering,
    end off no arguments to be had on this one,
    on the other hand if it was a 1.8t with a 28r or say a gt30r then yes id be looking for more then dot 4, being dot 5.1 but even then were only talking 40°C more in dry boing points 230°C vs 270°C
    but then if your going on track then you would sort brake cooling, go to the lengths of testing the water volume in the brake fluid and then also spend much more on bigger brakes,
    all of which isnt needed on a slow 1.8se
    Jun 2012
    Ireland
    59
    Im gona do brake fluid change tomorrow and decided to go with dot4 regular brake fluid cause theres no need to for me to have racing fluid cause i dont use my car on the track and its only 1.8se and price wise its extra 10 quid per liter on racing fluid.
  1. Power Steering Fluid
    By TrueNilbog in forum TT/TT-S/TT-RS Forum
    Last Post: 3rd October 2004, 02:24
  2. suspension and breaks
    By kmasjc2 in forum TT/TT-S/TT-RS Forum
    Last Post: 20th April 2004, 09:31
  3. Power Steering Fluid Leaking A4 2.8 1997
    By bradmcw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2004, 12:53
  4. Power Steering Fluid
    By blued in forum General Technical / How To
    Last Post: 28th August 2003, 13:23
  5. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
