Chris NottAH Fabrications
    Feb 2012
    12
    vac hoses help plz
    i am going to change my vac hoses on my 1997 a4 b5 1.9 tdi can some one tell me what size hoese to buy ie 3mm or 4mm ect thanx
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Take a couple off and measure them?
    On mine ,AJM engine code,I used 2 metres of 4mm and 1 metre of 5 mm
    tony
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,135
    Id say 3mm and 4mm and just get some force on it if its a bit tight as you wat it to be tight not loose like a wizards sleeve with a zip tie to hold it in place as it can loose vacuum if the sealing isnt right lol i have 3mm on my 1.8TQS and i struggleg to get 3mm on the forge 007p but with some force its on and not coming off without a good yank !!
  1. Replies: 4
    Last Post: 2nd November 2011, 21:17
  2. jabbasport chip needed HELP PLZ IM A NEWBIE
    By tick in forum General Chat
    Last Post: 4th October 2005, 16:15
  3. jabbasport chip needed HELP PLZ IM A NEWBIE
    By tick in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2005, 16:14
  4. help plz: recaro electric adjustment loom.
    By shortyp in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2005, 00:59
  5. hose help
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2004, 08:10
