Sky InsuranceBadger5
Results 1 to 16 of 16
    May 2010
    Val d'Isere
    85
    What's leaking now...2.5tdi Quattro?
    I noticed at the last oil change that I have a slight leak which looks like it's coming from between the engine and gearbox.
    I get a little patch under the car.
    What's it likely to be and is it an easy fix? I don't seem to be using any oil.
    Thanks in advance.
    May 2012
    Norfolk
    118
    If its engine oil and coming from defo inside the bell housing on box will more then likely be the rear main oil seal. If its gear oil will be input shaft seal
    May 2010
    Val d'Isere
    85
    Thanks. An easy fix?
    May 2012
    Norfolk
    118
    Rear main will mean gearbox off and flywheel to replace seal
    Input shaft seal means gearbox off and not sure if the input shaft seal it a bolt on nose cone type or an internal seal worst case is box will need opening up to sort it
    Jan 2012
    Malton
    276
    Check that it's not hydraulic oil from the PAS
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,116
    ^^ as above all 3 could be your problem or even rocker cover gasket leaking down the rear and into the bell housing !
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    what color is the oil?
    I'd expect engine oil on a TDI to be jet black, gear oil will be golden brown/reddy colored.
    TD5 Land Rover Defender build
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    253
    Agree with that. Even after a recent oil change it doesn't take long to go black. What's the mileage and age?
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    May 2010
    Val d'Isere
    85
    Quote Originally Posted by spartacus 68 View Post
    It's a 1998 coming up on 200k.
    Jun 2012
    Ireland
    59
    what about sump gasket?
    spartacus68's Avatar
    Jan 2012
    Aberdeenshire
    56
    Quote Originally Posted by gedi View Post
    First thing to do would be to whip off the plastic sump guard, then get under the car for a closer inspection. Unusual for the sump gasket to go in my opinion.
    Is that with or without VAT?
    2001 B5 A4 2.5 TDI Avant quattro sport (155k)
    2003 A2 1.4 TDI SE (125k)
    1995 80 TDI SE Avant (175k) sold
    May 2010
    Val d'Isere
    85
    I'm not losing engine oil but have noticed a drop in power-steering fluid so leaning towards this.
    However, why would that leak from round that area? What for and where should I be looking...
    May 2010
    Val d'Isere
    85
    Quote Originally Posted by Tom_B View Post
    I forgot to quote this in my last post...
    "Stick a V8 in it!"
    15,324
    PAS fluid usually leaks from the fittings on the cooler, or from the gaiters on the end of the rack.
    not sure how it would get inside the bellhousing though...
    May 2010
    Val d'Isere
    85
    It might not be coming from inside the bell housing, just gathering around it then dripping from it.
    "Stick a V8 in it!"
    15,324
    Stick your finger in one of the holes and see?
    My whole bellhousing was soaked in oil. Was pools of gear oil in the crevasses inside the housing.
  1. 1996 A6 2.5TDi Quattro Estate Glow Plug Problem
    By mmarks in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th May 2007, 20:13
  2. Help with choosing 2.5TDi Quattro
    By cyberdude in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2004, 21:42
  3. A3 2.5TDI QUATTRO
    By philsudbury in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2004, 19:15
  4. New 2.5TDi Quattro Tip =O)
    By TheTonsta in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2003, 17:32
  5. A6 Avant 2.5tdi quattro sport Tiptronic
    By jyeoman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th August 2003, 16:39
