Volks AutosChris Nott
    Jun 2012
    Audi A4 1.9 tdi turbo not "kicking in"
    Hi thereIm new to posting online but would be greatful if someone could help me.
    I recently purchased a W reg audi a4 1.9 tdi with 170k miles on the clock. I picked it up cheap enough so wasn't bothered about the milage.
    Now fistly I couldnt believe how good these cars really are ,as the mpg is amazing and the performance is quite decent too.
    Now im gutted as today when i pulled away from the traffic lights it felt like I was pulling away in an old transit van. It seems like the turbo is not "kicking in" and has become slugish and drives like a non turbo old type diesel. Ive read a lot of different things in different forums and have found a number of things it could be.
    But .....
    What is it most likely to be??
    Any advice is greatly appreciated.
    Many thinks
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,872
    Its most likely to be a number of things, to put it short you need to check the obvious vacuum lines and boost hoses Egr valve etc get it scanned for fault codes and the most cheap mod of all get some mr muscle oven cleaner down its guzzler !!!! As the vanes may be sticking !!!
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Feb 2009
    228
    As above, vacuum lines, n75, sticky actuator, carbon build up in the turbo and gunk in the inlets can all be fault found for less than a tenner and a bit of head scratching.
    Any of my early posts would be a good place to start
  1. 55 Pate Audi A4 2.0 TDI Turbo problem. HELP PLEASE!!!!
    By hronald88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th September 2009, 19:04
  2. Turbo not working properly + stalling? Audi A3 1.8T 2001
    By sparx in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2009, 23:27
  3. TURBO problems on AUDI A4 1.9 TDI
    By yiannis in forum The Welcome Section
    Last Post: 9th March 2009, 12:15
