AH FabricationsSky Insurance
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    2.8 quattro wheel bearings
    does anyone know how much front and rear wheel bearings are for a facelift 2.8 qauttro, and is audi the only place i will source them as eurocarparts dont stock them apparently.
    also what sort of job is it to do them? i do have access to a hydraulic press to get them out of the hubs
    and finally does anyone have the part numbers for them.
    cheers
    Jan 2011
    Aberdeenshire
    646
    Quick disclaimer :-I'm running 2.5TDi Quattros, they should be similar to yours, if not the same
    Try Jason at All German Parts for any bits, he'll sort you out and most bits are guaranteed, and all of good quality.
    The front were about £50-ish, the rears £25-ish for mine. Don't get pattern makes, I have just redone 3 of the 4 bearings on Mrs PaulFs car after fitting (not cheap!) ones from the local factors over the last year.
    It's ok to do, but if you are using a press you have to remove the front hub, which gives you the lovely job of the dreaded top pinch bolt. There are a few guides showing the front being done in situ, but I haven't managed. Last time I snapped a 24mm threaded bar trying.
    After reading all the trouble people had removing the ABS sensors, I didn't remove them. I just unplugged them. The rear sensors are connected under the rear seat.
    When removing the rear hub, mark the position of the eccentric bolt and washers before removal. If possible, you may be as well buying the 4 bushes and 2 eccentric bolts and washers while you are at it - they were shagged on both my cars.
    Both front and rear bearings have a step in them, check before fitting you have them the correct way around - it will prevent a 'DOH!" moment later.
    Again, if you can, get a 4 wheel alignment done afterwards - especially if you have changed the bushes and washers
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    jcb
    Sep 2005
    uk
    4,077
    dont get crap ones!
    Meyle/Lemforder etc
    Allgerman do them
    once you have one out whizz round it with a grinder and use it as the part to push the other ones out.
    lots of write ups on here
    Jul 2007
    London
    3,219
    SKF or genuine bearings for me, even the meyle ones aren't great !
    FOR SALE:
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Go for Genuine bearings.
    I replaced the front bearings on my FWD with supposedly German OEM bearings via Ebay, they lasted about 6k miles before I had to do the job again.......
    Was using a hydraulic bearing press that I bought specially for the job, so know they were installed correctly, it came in handy when I did the job again!!!
    Used Genuine parts the 2nd time and well over a year later and 10k miles they are still fine..........
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  1. How long does it take to replace wheel bearings on a B5 Quattro?
    By Tom_B in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2012, 18:31
  2. Quattro rear wheel bearing
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2010, 21:39
  3. a4 2.5tdi quattro rear wheel bearing
    By willieigs in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st July 2009, 09:14
  4. Audi 90 quattro wheel bearings..
    By patb in forum Classic Audi Forum
    Last Post: 19th June 2005, 12:28
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
