Sky InsuranceAH Fabrications
    boost-addict's Avatar
    Aug 2011
    977
    vcds lite, generic lead
    ok, so i understand that a genric lead isnt going to be any cop, but im getting responce from certain modules and can access faults
    but them others stating no response from controller
    depending on what im doing i get seprate errors, or like i say it works
    compatibility test, states this althou i can get in to modules like the instrumentation and alarm system
    ie
    but then try a diffrent one like engine or abs and get this
    the port test is fine low latency but its a cheap cable so expected
    then for some strange reason got this error, it started to read but then get this
    is there any other leads that are better other then a hex can ross tech
    this is the cable i got
    eBay - The UK's Online Marketplace
    im running window 7 64bit
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Klima does that for some reason, seems to be a fairly difficult module to talk to.
    You can adjust the latency by tweaking the settings in the system control panel for the USB serial driver, it defaults to 16ms, dropping it to 2ms or 4ms will improve things.
    The cable clearly works as you can talk to the instruments. ABS issue is probably because your ABS ECU is broken, i'm sure i've said this before to you, if you've got three beeps and a big (!) as soon as you power the ignition on the ABS ECU is faulty, and you wont be able to communicate with it.
    The engine is odd, could be a broken wire somewhere, or someones been hacking with the immobiliser wiring. You'll have to trace the wiring, i'd be looking behind the clocks for anything unusual patched in.
    TD5 Land Rover Defender build
  1. Replies: 3
    Last Post: 13th November 2010, 17:21
  2. VCDS-Lite not working :(.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2010, 22:38
  3. VCDS-Lite
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2010, 20:53
  4. NEW VCDS Micro-CAN LEAD ARRIVED TODAY WHAT COOL STUFF CAN I DO!
    By RGC in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th February 2009, 10:28
