Volks AutosAH Fabrications
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    Track rod end - easy to change??
    The drivers side track rod end is worn on the drivers side of my 98 A4. Audi want Ł350 to change it and tell me its not covered by the approved used warranty - anyone know if it should be?
    Can anyone tell me if these are fairly straight forward to change?
    Thanks.
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Re: Track rod end - easy to change??
    Aha!.. Ask user xvw, he has the same issue and apparently it IS covered by the warranty so read the small print...
    The911SC's Avatar
    Sep 2003
    1,032
    Hmmm... but if it says '"Steering system: All parts including from the steering wheel TO the track rod ends"
    Does that then mean everything inbetween the steering wheel and the track rod ends i.e not including them!?
    Just playing devil's advocate! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    imported_VaulterTim
    Fair enough, but I reckon if it's anything BUT totally clear then it's fair game to argue about...
    And they do say 'including'...
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    Thanks for all the replies.
    I tried the dealer again as well as Audi UK, but they both tell me it is not covered by the warranty. I now have it booked in at an independent to get it done - he reckons it will only be Ł50 to change it!
    To be honest I don't think I would trust the dealer (Edinburgh Audi) to change it seeing as at the service they over tightened the wheel bolts (to over 250nM), set all the tyre pressures to 30 psi instead of 36 and told me both front tyres had 4mm tread left despite the passenger one being bald at the edges and only having 2mm in the middle - if they can't even get stuff like that right..........
