EM TuningSky Insurance
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Testpipe and fault codes
    Firstly, Anyone selling a decat pipe/Testpipe?
    Secondly:
    17743/P1335 - Engine Torque Monitor 2: Control Limit Exceeded
    What could cause this... was on part throttle cruising, so no real load on the engine... anyone had any experience of this DTC and what did you find was the cause?
    Currently rolling in a SKODA!!!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    Quote Originally Posted by Der_Techniker View Post
    Secondly:
    Is this what you looking for?
    Classifieds: cheap decat pipe - B5 A4 1.8T
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    boost-addict's Avatar
    Aug 2011
    977
    ecutuning is were ill be getting mine, has two lambda holes, good for ecu lambda and a wideband one.
    works out about £100
    17743/P1335 - Ross-Tech Wiki
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Reduced Power
    Possible Causes
    • Intake hose(s) or intake system leaks (Unmetered Air) after MAF
    • Intake Air Temperature sensor faulty
    • Mass Air Flow Sensor (G70) faulty
    • Engine Coolant Temperature sensor faulty
    • Restricted Air or Fuel Filters
    Possible Solutions
    • Check intake hose(s) or intake system for leaks (Unmetered Air) after MAF
    • Check Intake Air Temperature sensor
    • Check Mass Air Flow Sensor (G70)
    • Check Engine Coolant Temperature sensor
    • Check Air and Fuel Filters
    Special Notes
    Arrkon's Avatar
    Oct 2010
    1,633
    • Leaks - Possible
    • IAT sensor - Brand New
    • MAF - Brand new
    • CTS - Brand New
    • Filters - Brand New
    Anyone got a Pressure tester?
  1. Engine management light on with fans running and 2 fault codes. HELP?!
    By Crunch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2011, 12:22
  2. MAF and Fault Code 16486
    By tompearson in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2011, 16:10
  3. Logs And Fault Codes
    By cecilthesausage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2011, 16:16
  4. Replies: 2
    Last Post: 19th December 2010, 20:41
  5. Replies: 5
    Last Post: 18th January 2010, 23:36
