Monster MotorsportEM Tuning
Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By aragorn
  • 1 Post By HEKTOR
Thread: Gearbox now out
    Apr 2006
    A, A
    269
    Gearbox now out
    Right chaps, gearbox is now out and being rebuilt as we speak, wanted to change clutch whilst it's out but don't know what to go for?
    My car is running 352bhp at the mo but should go to 370 bhp after full milltek exhaust fitted without cats along with a remap from MRC.
    Now spoke to Jason at AGP and he said the flywheel on a S4 and a RS4 are the same so all I need to do is change the clutch. So is a standard RS4 clutch good for this bhp.
    Andy
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Of course it is. RS4's are 380bhp as standard!
    I've been running over 400bhp on RS4 clutches for about 4 years now. Never had any issues with slipping.
    Do you have hybrids fitted?
    Mo power, mo problems
    Apr 2006
    A, A
    269
    These are the parts I collected today for my gearbox rebuild, should be done the end of the week ready for installing.
    CraigG's Avatar
    May 2008
    188
    you are not in a million years getting a true 370bhp out of stock K03's
    your current "352" is simply happy dyno syndrome, and is more like 320-330 if your lucky.
    An RS4 clutch is perfectly capable of handling any power you will be able to achive from K03's
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Apr 2006
    A, A
    269
    Never said it wasn't a happy dyno but obviously you know my car alot better than me and the dyno centre I took it to. Love people like yourself who arn't happy unless your being pessimistic. Stock K03's? they may be or they may not be, I honestly don't know what they are as no history to back this up. Once all the bits is done I will get it on a dyno and see what it reads. RS4 clutch is being fitted for my K04's when these K03's blow up. Please tell me when this will happen so I can plan a week off work to swap them over oh wise one.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,914
    You decided to replace all 6 synchros, rather than just the 1st/2nd gear items?
    There are plenty dynos around that report wildly optimistic figures, Prawn off here had something like 20-30hp more when he ran his car on AMD's dyno, compared with the dyno of the guy that mapped it.
    Its generally accepted that standard K03 turbo's wont make much more than 350hp, with all the boltons and a really strong tune. Your car is apparently on its stnadard restrictive downpipes, and stndard intercoolers, so it certainly shouldnt be making 350hp. Ok theres a possibility that someones replaced the turbos with nice hybrid versions, but then ofcourse that would be a selling point when the come to sell the car and it would be well advertised. As such its surely more logical to conclude the car isnt actually making 352hp.
    Theres no need to get arsey, its been suggested to you a number of times that the figures your quoting dont make any sense for the car and its modifications, and your clearly ignoring these comments and still thinking your cars going to make 370hp.
    TD5 Land Rover Defender build
    Apr 2006
    A, A
    269
    Yeah as once box was out the fitter said to change the bork ring but there has been an upgrade so the syncs had to be changed also, got a good deal with all 6 I think. The hub was the killer mate, it worked fine but was showing signs of wear/failure. Better to be safe than sorry.
    Never heard of TPS until the gearbox lad told me about it, pleased he did.
    "Stick a V8 in it!"
    14,914
    Thats typically what happens, the syncros get weak, resulting in a missed shift and a massive grind when your giving it some. The massive grind blunts off the tips of the teeth on the hub and it jams.
    Apr 2006
    A, A
    269
    Yep thats what the guy said, going to give me the old parts back, take some pics and put them up I guess. Box should like new I hope. Getting a really good price on the rebuild as I have passed him alot of work over the years. Down pipes are being made by A.A.S and they should be done Thursday. Once all back together I need to get the tracking setup as changed sus arms and bushes on each corner.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,877
    Hmm i seem to have a stiff 2nd gear from cold and also a terrible noise at idle when i rev it coming from the box near the n/s/f driveshaft which goes if i press the clutch, is it time to pull the box again and get 1st and 2nd replaced ??
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    14,914
    not usually an issue on the 012 boxes tbh, only the S4 box seems to suffer.
    Aug 2010
    2,877
    Is there any known problems with the gearbox on the TQS as i did the prop flange seal at weekend and i was thinking it may have been lack of gearoil but the oil was like new not one bit of swarf in the box really, thought its a 01A box in the TQS ??
    Here you go andy think this is what you need - AUDI A4 A6 RS4 2.7 3.0 4.2 CLUTCH COVER 079141117DX NEW GENUINE AUDI PART | eBay
    GENUINE AUDI A4 S4 A6 2.7 4.2 3.0 6 SPEED 240MM CLUTCH DISC PLATE 059 141 031 P | eBay
    Apr 2006
    A, A
    269
    Thanks Bradderz but bought a clutch kit from AGP the other week, need to get going on this really as it breaks my heart to see her just sitting there in bits lol
    "Stick a V8 in it!"
    14,914
    I believe the 01A is the FWD version of the box, 012 is the quattro version.
    Apr 2006
    A, A
    269
    Collected gearbox yesterday, the guy charged me £295 to carry out all the relevent work and replaced all parts on list above. I'm happy with that I think.
    HEKTOR you say nothing ;-)
    Oct 2008
    Glasgow
    430
    Quote Originally Posted by adidasandy View Post
    Im still in shock at the cheapness!
    "Stick a V8 in it!"
    14,914
    Maybe your just too accustomed to being ripped off with the RS Tax :P
    adidasandy likes this.
    Oct 2008
    Glasgow
    430
    I think you are right :-( I think audi and the tuners see us s/rs owners coming ;-)
  1. 2.0 tdi sline dsg gearbox cutting out
    By MisterP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 17:56
  2. did anyone find out where adam etc are now from AMD?
    By edward_harris in forum General Chat
    Last Post: 8th May 2007, 23:22
  3. Replies: 29
    Last Post: 4th July 2006, 14:48
  4. Nearly out of warranty...what now ?
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 09:32
  5. I took the battery out of ny TT and now my radio w
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2004, 19:19
