Results 1 to 9 of 9
    May 2012
    Harrogate
    23
    Alarm/Central Locking issues
    Hi,
    I am new to the Audi world and am having a problem which I hope is an easy fix (battery maybe?).
    Basically, the car has stopped 'beeping' when I lock it (most of the time) and the boot sometimes sounds like its taking longer to lock than the rest of the car. Also, last night the alarm went off for no apparent reason (could have just been a cat or something I guess) which was odd.
    The dial that shows a picture of a battery is constantly sitting at 4/5ths of the way towards full.
    Any idea chaps?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,934
    The battery guage shows the alternator output, and it should sit at 14v with the engine running.
    The sierns are prone to failing, usually because the batteries inside leak, and wreck the circuit board. You might get lucky by removing it, cleaning the board and replacing the batteries, but if its too far gone you'll need a replacement siren.
    TD5 Land Rover Defender build
    May 2012
    Harrogate
    23
    Is that an easy job? I will crack te Haynes manual out tonight and have a go.
    Do you think that the alarm going off randomly last night could be linked?
    Thanks for your help
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,066
    Going by your other posts yours cars a 97?
    If so you won't have a battery siren so it's more likely the alarm isn't setting properly, check bonnet switch works that's the most likely cause
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    May 2012
    Harrogate
    23
    It is indeed a '97. Sorry to sound like a proper dunce but what exactly am I looking for and how do I check. I should have mentioned that although keen and quite handy, I am a proper novice with this stuff.
    "Stick a V8 in it!"
    14,934
    ah ok, earlier cars dont have a siern, just a simple horn which never really fails.
    As olds_kool says, its likely a fault with one of the door/bonnet/boot switches, so the alarm thinks its open.
    Vagcom might help you diagnose.
    May 2012
    Harrogate
    23
    Aragorn- can you advise me a little more on vagcom? I know what it is essentially yet there seems to be a range of prices for leads & software between £18 and £250!? Incidentally, when I locked my car last night I got no 'bib' but this morning I did.
    "Stick a V8 in it!"
    14,934
    Vagcom is a commercial package which comes with some software and a lead and costs ~£230.
    The company however also release a free "lite" version, which can be used with cheap ebay leads but giving you a lot less functionality.
    You also have the option of activating the Lite version, which ends up as a sort of half way house between the full version and free version in terms of functionality.
    The free version will do what a lot of people need, which is read fault codes, so in that respect its limited but still useful.
    Does your interior lighting work as expected when you open/close the doors? Same with the boot light?
    If so, i'd try unplugging the bonnet switch and see how you get on.
    May 2012
    Harrogate
    23
    I think you might be right with the bonnet sensor. The alarm went off twice for no reason. I don't know where to find the sensor though. There is no diagram in the manual. I'll check my Haynes as well. Might get the cheap leads and have a try at the free version of vagcom too.
  1. central locking issues, a6 4.2 quattro 1999 saloon
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th June 2010, 17:06
  2. Alarm/ central locking problems on 99 B5
    By B5_Avant_AAN_Powered in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2010, 19:52
  3. Central Locking Issue!
    By eddie659 in forum RS6 Forum
    Last Post: 27th January 2010, 09:40
  4. Central locking issue
    By IainW in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2009, 18:53
  5. alarm / central locking - no siren
    By sun and kath in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th December 2006, 15:41
