Sky InsuranceJMB Retrofits
    Winchmore's Avatar
    May 2012
    Sheffield S11
    32
    Follow Winchmore On Twitter Visit Winchmore's Youtube Channel
    Audi A4 Auto - Help with DTC codes - Car going in Limp mode
    Car goes in Limp Mode – DTC light
    #1) 17976 x 2 -Not listed on Ross-Tech but may be re throttle
    #2) 17967/P1559/005465 - Throttle Body (J338): Fault in Basic Settings
    #3) 17972/P1564/005476 - Throttle Actuator (J338): Under-Voltage during Basic Setting
    #4) 17973/P1565/005477 - Throttle Actuator (J338): Lower Stop not Reached
    #5) 17950/P1542/005442 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
    #6) 17579/P1171/004465 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
    17967/P1559/005465 - Ross-Tech Wiki
    17972/P1564/005476 - Ross-Tech Wiki
    17973/P1565/005477 - Ross-Tech Wiki
    17950/P1542/005442 - Ross-Tech Wiki
    17579/P1171/004465 - Ross-Tech Wiki
    Capacitance Discharge (disconnecting the battery and shorting
    the terminals together) may help with 17976 not sure about the rest
    Need help - please advise
    New to the forum
    Sheffield S8
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Welcome to ASN. One of the guys should be along shortly. Enjoy the forum. Have a through information available in threads.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Looks as though your throttle potentiometer has failed. could be a simple fix (go to measuring blocks, enter 060, then click on "basic settings") to run the throttle alignment, or the throttle may be genuinely faulty.
    Currently rolling in a SKODA!!!
    May 2012
    Norfolk
    118
    Sounds like it needs a good clean out and the Adaptation re-done if the above does not sort it worth trying that before you go buying a new one.
    Did you try clearing the codes and see what ones return ?
    Winchmore's Avatar
    May 2012
    Sheffield S11
    32
    Many Thanks !
    Going to get local garage to clean and reset.
    Will also get the spark plugs changed...not done for a long while. Which ones NGK or Bosch ....model? - V6 2.4 Auto engine
    "Did you try clearing the codes and see what ones return " no will alos give it a go
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Check the wiring plug for corrosion.
    Mine had fault codes like that and there was some crust on the pins on the throttle body, i sprayed in some WD40 and plugged/unplugged it many times and that sorted it.
    TD5 Land Rover Defender build
  1. Help with this code please...
    By terrymcg in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd July 2007, 17:28
  2. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
  3. Help with Vag code?00561 - Mixture Adaption limit not reached - Interm
    By imported_ChrisCardiffA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2005, 09:44
  4. HELP WITH VAG CODE! O2 SENSOR?
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 12:22
