Volks AutosMonster Motorsport
Results 1 to 23 of 23
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Brake Pads - Advice Needed
    what are the best, Sensibly Priced, brake pads to use with drilled/grooved discs? Ideally with as little dust as possible.
    When I say "sensibly" I mean, around the £30 mark, not the EBC Green £80...
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,876
    I use mintex red box with grooved and drilled have no probs £25 quid through work from andrew pages.
    Little dust and stop a treat even when im giving it some.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Pagid within that price range mate.
    May 2010
    Bedford
    2,877
    Pagid from Euros probably. Good for the money and Pagid make OEM brakes for the likes of Audi and Porsche as an example of reputation. Ideally you dont want drilled discs at all though as its common knowledge they crack with heat.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Arrkon's Avatar
    Oct 2010
    1,633
    Quote Originally Posted by Jason.s View Post
    Yeah, i have heard this, but then i have seen ones that have been run for a couple of years with no cracking. Bradderz, have you had any issues?
    Aug 2010
    2,876
    No not yet only been on for 2 months and they seam to keep the pads cool as well very noticable differance to the old brakes but they were 288mm now im running 312mm so could be the braking force differance.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    I run mintex redbox on the avant along with 312's but i'm not that impressed with them TBH. Not sure if its the disks or what, but they're a bit crap. My own car has 288's and some unknown pads and seems far more "bitey"
    I plan to replace them with Ferodo Premiers, as they seem to get a good write up by the S/RS folks.
    TD5 Land Rover Defender build
    boost-addict's Avatar
    Aug 2011
    977
    yer them discs some times crack, but its becasue people dont put them though proper heat cycles and expect them to stop them with 100% effecency from 70/80mph straight away. i had drilled discs on my 325i e36 and i went though heat cycling ie, braking lightly from 30mph 2/3 times then a bit harder from same speed, and then a long distance braking break in cycle from 70, say over 1/8th mile.
    always bed in my brakes like this and never had problems. and infact find they then brake alot harder then if you just let them bed in nataurally. thing is i hate new brakes but its a must when they are needed to be changed, i do this becasue i hate the thought in the bed in period im going to really need my brakes and not have any response and they glaze up.
    if you want cool running brakes just by ebc turbo groove discs, i know there expensive but there worth the cash lay out
    May 2010
    Bedford
    2,877
    No its because they`re drilled after the casting process. If they were cast with the holes like Porsche/Ferrari/Lambo and so on drilled discs are then the problem wouldnt appear. Grooves are also there to dispurse the build up of brake dust not aid cooling. Thats what the drilled holes are supposed to be for but really you dont need drilled/grooved discs. Even on a track car a set of blank discs are fine.
    Aug 2011
    977
    granted. but not treating them correctly cracks them prematurly
    May 2010
    Bedford
    2,877
    Well yeah the bedding in process is important so fitted them and jumping on the brakes straight away will kill them but still the main culprit is the manufacturing process. A drilled disc is just a normal blank disc pulled off the shelf and had a drill taken to it.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    I use Brembo pads from these guys
    Audi A4 1998 1.8 Brembo Discs & Pads
    The fluid ran out of steam before the pads did on track
    Life begins at 140mph
    www.passionford.com
    Aug 2011
    977
    thats good to know oranoco, im about to buy these, for the rear
    eBay - The UK's Online Marketplace
    and then go for the slotted ones with yellow stuff for the front,
    or should i get these ones
    FRONT BREMBO MAX BRAKE DISCS AUDI A4 Avant 1.8 T quattro 147BHP [96->01] | eBay
    few £ cheaper then your link
    so brembo max discs with yellow stuff on the front ~(iirc there the ones with cold grab and med/long life, as green are short life again iirc)
    and brembo discs with brembo pads
    again with yellow stuff pads. and brembo pads on vackback
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    Personally I will never use an EBC product again after the issues I've seen with their Greenstuff pads. Shop about and see what you can do. I ordered mine from the link I posted at 3pm and by 10am they were in reception in my office
    www.passionford.com
    Apr 2012
    N. Wales, LL22
    1,224
    green stuff = ****e
    ds2500 is where its at
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    "Stick a V8 in it!"
    14,907
    A disk is a disk. Theres no point IMO spending stupid amounts of money on fancy drilled/grooved disks when its the pads that make all the difference.
    Standard motorfactors disks, and good pads are all you need. If you want to waste money on disks, then forget off the shell drilled/grooved tat, and get some alloy hats and floating rotors made to fit your setup.
    Given the budget of "around 30quid" then obviously any "performance" pad is not in the running. However given your talking about wasting money on disks, i'd suggest that instead you fit standard disks and some decent pads.
    DS2500's are a popular option for fast road, but also worth looking at are Mintex M1144 as they're quite a bit cheaper.
    Aug 2011
    977
    it wasnt me that said i had £30 budget. so your saying just plain brembo discs with ds2500 for the fronts?
    and for the rear are these the correct ones for the rear on a 1999 a4 1.8t quattro sport
    "Stick a V8 in it!"
    14,907
    No, but the original poster said £30!
    and yep, just whatever plain disks you fancy, I use mintex or whatever my local factors happens to stock.
    The ebay link looks about right to me.
    Personally though, i'd try to run the same pads front and back.
    Aug 2011
    977
    that link. is there not ment to be pad pad wear indicators, dosnt show them on there, i pursume being brembo there come as per oem specs regarding the pad wear indicators.
    "Stick a V8 in it!"
    14,907
    Wear sensors are only on the front.
    Aug 2011
    977
    thats strange, as i have low pad warning light but fronts are ok, maybe one side is lower then the ot side, not looked properly, but going to do back and front all at the same time.
    Aug 2011
    977
    ok so going for these now, checked compatibly and says it fits
    This item fits 2 version of the Audi A4 1999 8D2,B5 [1995-2000] Saloon 1.8 T quattro :
    Please check if your vehicle is in the list and if there is no restriction for your vehicle in the notes field.[show all compatible vehicles]
    Notes Make Model Year Variant Bodystyle Type Engine
    Audi A4 1999 8D2,B5 [1995-2000] Saloon Saloon 1.8 T quattro 1781ccm 180HP 132KW (Petrol)
    Audi A4 1999 8D2,B5 [1995-2000] Saloon Saloon 1.8 T quattro 1781ccm 150HP 110KW (Petrol)
    Eicher Rear Brake Disc for VW Passat / Audi A4 | eBay
    and brembo pads
    This item fits 1 version of the Audi A4 1999 8D2,B5 [1995-2000] Saloon 1.8 T quattro :
    Notes
    Important part details
    8D-X-200001->. PR:1K...
    Audi A4 (8D2. B5) 1.8 T quattro Brembo Rear Brake Pads 12/97-11/00 | eBay
    as this is my first audi, and being a quattro, i want it to be right first time, and i know you lot here are well up on what bits are correct etc. thanks
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,922
    Quote Originally Posted by boost-addict View Post
    If it's the same as the Golf the sensor is only on the inner n/s pad. Check the sensor wire is still attached and the condition of this pad as it's feasible for the pads to wear unevenly as the sliders are often neglected
    www.passionford.com
  1. Brake pad advice
    By A4CAB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2010, 18:55
  2. front brake pad problems, advice needed please
    By Diesel_Seb in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2009, 11:51
  3. S3 Brake Pad advice
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2005, 22:15
  4. Need help on brake pads
    By mazzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2004, 10:10
  5. need new rotors and brake pads
    By imported_ebang in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th August 2004, 18:13
