Volks AutosSky Insurance
    Jan 2012
    London
    EGT/MAF resistance?
    Hi all, EGT's are coming up on diagnostics and the cars running a but rough on idle which i suspect to be the MAF. Does anyone know the resistance for the egt and maf pins? (B5 S4)
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,646
    Pull the MAF plug, the ecu should default to baseline tables. If it runs better then it's def at fault.
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    EGT doesnt really have a resistance, its an active device which sends back a PWM signal.
    Similarly the MAF gives out a voltage corresponding with the airflow.
    TD5 Land Rover Defender build
  1. Egt n710 lambda MAF prices etc
    By Matt82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th November 2009, 08:49
  2. maf sensor
    By tvr1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 09:52
  3. MAF
    By Speedy in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2003, 09:44
  4. MAF Cleaning (used to be "Technical Forum")
    By Joshie in forum General Technical / How To
    Last Post: 3rd February 2003, 10:39
  5. MAF Cleaning (used to be "Technical Forum")
    By Joshie in forum General Chat
    Last Post: 6th January 2003, 15:55
Tags for this Thread
