Sky InsuranceChris Nott
Results 1 to 7 of 7
Thread: A4 Stereo
    Oct 2005
    sweden
    A4 Stereo
    Hi
    Can anyone tell me if the wiring for a "Concert" stereo is different to the wiring for a "Delta"
    Ian
    Jun 2003
    World of my own
    9,813
    Re: A4 Stereo
    No it's exactly the same, although the Delta has an external antenna amp and the Concert is internal.
    Oct 2005
    sweden
    Re: A4 Stereo
    I Have fitted the Delta to my 98 A4 which used to have a concert in it prior to me buying it, but the Delta keeps going back to the "Safe" mode every time I switch off the ignition
    Jun 2003
    World of my own
    9,813
    Re: A4 Stereo
    Yeah the ignition on & perm live are the wrong way round. Swap over the yellow (red stripe) & red (white stripe) wires on the black power iso block.
    Why would you retro fit a Delta it's worse than the Concert (and that takes some doing)?
    Oct 2005
    sweden
    Re: A4 Stereo
    It had a cheapo Goodmans in when I bought it the "original" had been removed, picked the "Delta" up on a car boot sale for 2.00, can't complain.
    Oct 2005
    sweden
    Re: A4 Stereo
    I don't have yellow (red stripe) & red (white stripe) wires on mine
    Wiring on ISO plug
    1) White / Blue
    2) No Wire
    3) Green / Blue
    4) Red
    5) No Wire
    6) Grey / Blue
    7) Red / Blue
    8) Brown
    Symbols on Stereo
    1) GA
    2) Mute
    3) +
    4) S- Kont
    5) + _/ _
    6) Light Symbol
    7) + UB
    8) Earth Symbol
    Any ideas on which goes to where and how do I get the wires out of the ISO block without cutting them
    Ian
    Jun 2003
    World of my own
    9,813
    Re: A4 Stereo
    Swap S-Kont (ignition on) with +UB (perm live).
    You can release the pins in the ISO block using a very small screwdriver. Poke it in to the rebate next to the pin and bend it over away from the pin and with some trial & error you can pull the pin out using the wire. Alternatively just buy a male & female wired ISO blocks and use them to Xover the wires.
