Results 1 to 19 of 19
    boost-addict's Avatar
    Aug 2011
    977
    vagcom/tacho and getting in to the ecu. as i cant?
    ok so looking to get vagcom/tacho because firstly my abs light is on and says theres a fault in the abs system. had it on a reader from a garage were a mate works. he tried accessing the ecu via normal route and then directly via the abs system, both reporting "no systems found" now will vcds get in? any one heard of an ecu blocking out a reader? some one at audi said it could be chipped and a reader wont bring anything up due to it being chipped
    also need to change my clocks as you cant read the lower half. and didnt realise the clocks have to be recoded till i installed the new one! so swapped all back over and discover i need vag-tacho. im in to it and mechanical things so will v.tacho be simple enough to use, as i also need to change the new clocks from 127k to my olds clocks of 150k.
    so
    1. will vcds access a ecu that refuses to be read by a diagnostic reader
    2. is vagcom/tacho easy enough to use one learnt
    3. are these the right tools for the job
    vagcom
    eBay - The UK's Online Marketplace
    vag tacho
    Jun 2011
    Great Melton Norfolk
    1,356
    The vagtacho cable is a copy and the vcds too. VCDS lite doesn`t do scans of individual modules.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    both fakes good luck with them
    Aug 2011
    977
    ok, so were best to get one with out it being hundreds of pounds.
    i may well get it scanned down at apr. but thinking if i can get vagcom cables and then buy full version, think its $99 then should be good to go. but if these fake ones or copies wont do the job is there any cables on ebay or other wise that i can get.
    also while were on the point. is there any reason why the ecu port wont communicate with a diagnostic reader?
    have a abs light up. but the abs osr was replaced, looking though the paper work its had every corner replaced in the last 5 years so thinking get 4 new sensors, can a faulty abs unit make the abs light come up?
    also as i have a aftermarket unit does the k/data line need to be looped to a certain wire, grounded or to a switched live?
    Apr 2012
    N. Wales, LL22
    1,224
    i got an £8 cable, worked fine with vcds lite
    ive now upgraded to a usb-hex-can one and its and investment as they sell for £££ on ebay so you will never loose out!
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Aug 2011
    977
    yer thats fair enough but i dont need the cable so much i want to spend £300+ on a cable and software
    so you saying i cant use a copy vagcom cable with full vagcom software?
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by boost-addict View Post
    if you want full you have to buy a genuine cable with the licence built in
    VCDS in North Wales
    Aug 2011
    977
    so i dont want to adjust all the mudules, although would be nice, all i want to do is read codes, erase them and log
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    £8 cable and the free version of the software will be fine then.
    If the ABS warning is on as soon as you turn the key, along with three beeps, the ABS ECU is probably broken, which explains why the snapon kit couldnt connect.
    TD5 Land Rover Defender build
    Aug 2011
    977
    yes, abs light is on as all other warning lights, then 3 bleeps and then flashing warning, which is ever so annoying,
    so do i need to match the ecu seriel numbers like the main ecu?
    hopefully itll sort it. will vagcom tell me, not the free version but a proper scan?
    "Stick a V8 in it!"
    15,388
    If the ECU is broken then the vagcom lead will do the same thing as the snapon thing, ie it wont be able to connect.
    Aug 2011
    977
    ah ok, i mean full vcds, so do i need to match serial/part numbers or can i buy any ecu as long as its for my model/year
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    The normal fix for this is to have the abs ecu repaired. There are a number of people who do this (e.g. BBS Reman). Basically you can take the ecu off the pump and send it off for testing\repair. There are lots of threads on this and a guide on the audiworld tech articles. I had mine repaired this way, its quite straight forward.
    There are also a few guides around on fixing the ecu yourself which involves soldering back some very fine wires!
    Good Luck
    Aug 2011
    977
    whats the cost on that? and didnt have any luck finding a guide, got a soldering magnifiying glass so i could do it. also have a goos iron and one with a very thin tip for such work
    Aug 2011
    977
    well looks like the unit has been touched twice or at least that.
    has these stickers on
    Jul 2007
    London
    3,252
    It's funked then ! Most repaired units i've seen don't last long !
    FOR SALE:
    brasiliangringo's Avatar
    Mar 2010
    544
    Interesting, fairly sure my old S4 had a lynx sticker on the engine ECU after i bought a 'new' one from the repairer.. (the original ECU stopped working)
    Aug 2011
    977
    mmm, can i buy a s/h unit that is gurenteed to be working. do i need to match numbers like you do with the main ecu
    and would the buggered abs ecu prevent the main ecu being accessed via the purple coms port?
    if so am i able to remove the plug to stop this to get a scan?
    also forgot to ask, if i remove the abs ecu, am i able to drive the car while its being repaired or will it not run, thining a fail safe might be in place?
    Jan 2011
    Aberdeenshire
    646
    Yes, there are about a million different part numbers.
    If you look on the pump for the number, and ONLY get the same part number, you will be ok. You may, or may not have to code the unit (with VCDS). IIRC, traction control units will need coding, non traction control don't - but check!
    There probably is at least one, or most likely three, alternatives. This can be checked with ElsaWin.
    You can remove the module from the pump, and continue to drive without ABS, but with functioning brakes.Seal the pump up to prevent s*** ingress. This allows you to send it away to the likes of ECU Testing, or such-like for repair.
    They will also fix your clocks (they did mine, after BBA Reman s****d mine)
    You probably can't access the main ECU due to the copy unit being set up wrong. Check what ports are being used. You wont get much help or sympathy on this forum, as many here get excited about clones (as some replies here have shown - GIYF). I don't care, but I have a genuine lead because I think it's good enough software that RossTech deserve the cash! I made the cost back with a couple of timing checks and a recode. It saved me a lot of b*******g about too. Your choice.
    Last edited by PAULF; 31st May 2012 at 22:19. Reason: Speeling (AGAIN - stupid laptop keyboard!)
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  1. ECU not Communicating with vagcom....HELP!!!!
    By camscockle20vT in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2010, 11:16
  2. Disable ECU via VAGCOM
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2010, 14:11
  3. Vag-tacho cables - which one?
    By jasper2447 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th May 2010, 13:41
  4. Vag Tacho Help Please?
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2009, 11:53
