EM TuningVolks Autos
    May 2012
    Harrogate
    23
    Intermittent Brake Light issues - please help?
    Hi,
    I have just purchased an AUDI A4 TDI 110 SE 1896cc, 4dr Diesel Manual (1997 - R) and when following it home I noticed that the brake light on the drivers side was only working some of the time. As this is my first Audi, I though tI would ask if it is a common problem with a common fix?
    Any help would be appreciated.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    take the bulb out and check the contacts for dirt/corrosion. Also, check the multi plug that powers the lights for dirt etc
    2002 2.5 V6 Quattro
    May 2012
    Harrogate
    23
    Quote Originally Posted by S4_dan View Post
    Thanks. Have cleaned the contacts and checked the leads that go into the light fitting all seems well at the mo. much appreciated!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    tried a new bulb?
    TD5 Land Rover Defender build
    May 2012
    Harrogate
    23
    If it was the bulb would it not be constantly off?
    Cleaning contacts etc hasn't fixed it permanently. I'll try a new bulb. Any suggestions of that doesn't work chaps?
    "Stick a V8 in it!"
    14,904
    I've had a bulb act up in a similar manner. Eventually it did properly blow, but for a few weeks before that it randomly triggered the bulb warning.
  1. Brake pressure release solenoid (F84) intermittent
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Weeks Ago, 17:30
  2. Intermittent centre brake light warning on DIS!
    By Abb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th September 2013, 23:16
  3. Replies: 0
    Last Post: 9th September 2010, 12:34
  4. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
  5. HELP PLEASE!!!!!!! Intermittent brake lightfailure
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2003, 23:20
