    Apr 2006
    A, A
    269
    Vibration when braking from high speed
    Noticed a vibration / wobble when braking at high speed. The wobble comes through the steering wheel but not too bad but when looking at the gearstick it going mental. Only does it now and then but feels like it's from the O/S/F somewhere.
    Not discs, wheels or tyres as these have been checked today. Do these suffer from strut top mounts failing?
    Andy
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,865
    Mines started doing it and i know that the engine/drivetrain mounts and suspension arms have seen better days probably been on there since factory, so going to put that on my next job of things to do its from the n/s/f and only at high speeds say 60-100mph obviously the faster i am going the more vigorous the shake becomes.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Worn control arms? How did you check your discs?
    Mo power, mo problems
    Apr 2006
    A, A
    269
    Brand new discs and new arms through out, was doing this before I changed them aswell.
    Andy
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If its only doing it when braking, then its pretty likely to be an issue with the brakes. Perhaps some crap on the hub stopping the disk sitting square, or you've not been treating them properly and have managed to get pad deposits on the new disks already.
    TD5 Land Rover Defender build
    Apr 2006
    A, A
    269
    treated fine, does it more when braking but can feel something when driving normally.
  1. Question - Can Warped Discs Cause Vibration Noise whilst NOT Braking?
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2011, 11:56
  2. Vibration at high speed ....thought's anyone
    By 10blazin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2010, 21:31
  3. Problem when braking from speed??? :(
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2009, 12:25
  4. Vibration under braking
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2006, 20:11
  5. Noise when braking at high speed ?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 15:09
