Chris NottBadger5
Results 1 to 13 of 13
Thread: Oil light
    imported_billybravo
    Oil light
    hiya all
    ok when i start my car up oil flashers under the miles on the clocks ive checked it and the level is fine can anyone tell me what it is
    thank you guys
    Jun 2003
    Hythe, Kent
    1,180
    Re: Oil light
    Probably the sensor on its way out, search on here, there was a thread fairly recently about it.
    Kev.
    imported_billybravo
    Re: Oil light
    thanks mate
    Jun 2003
    Hythe, Kent
    1,180
    Re: Oil light
    Here you go link.
    Kev.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Re: Oil light
    isnt that just the Oil service indicator??
    imported_billybravo
    Re: Oil light
    yeah it must be cos ive just found it in the good old book
    Milton Keynes UK
    248
    Re: Oil light
    It is the oil service indicator warning light.
    You can reset it by following the instructions below -
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    Depending on what service light is displayed (IN1 or OIL) you might have to play around with it to reset the correct one.
    This works on my A4 tdi (110bhp) but should work on all.
    Hope this helps.
    Jim.
    imported_billybravo
    Re: Oil light
    your a star mate im gonna have a look right now!
    imported_billybravo
    Re: Oil light
    right i tried it but as soon as i turned the ignition it went off right away and didnt flash just went back to 00miles
    but if i turn it back off oil just flashes again
    Milton Keynes UK
    248
    Re: Oil light
    Play around with it, you might have reset the IN1 service light and not the OIL service light.
    It took me a couple of goes before I got it right.
    imported_billybravo
    Re: Oil light
    ive just found out that mine has to be reset with the vag cable because its a n reg 95 to 96
    im going to buy one from ebay but where do i get the software from ??
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Re: Oil light
    imported_billybravo
    Re: Oil light
    is there anyone who could do me a copy im in the stockport area
    thanks for your help [img]/ubbthreads/images/graemlins/smile.gif[/img]
