Sky InsuranceAH Fabrications
Results 1 to 17 of 17
    Jan 2012
    Malton
    276
    Wobbly fan TDi V6
    The car has some vibration - not bad , but noticeable at about 2 k revs. When I had a look at the motor ticking over I noticed that the right hand fan (standing at the front looking into the engine bay) which is made of plastic is not running true. Does this matter and could it be causing the vibration felt through the car?
    Aug 2010
    1,540
    a bit of wear/rock in the viscous fan is pretty normal. doubtful if its the viabration you can feel.
    can this be felt when holding 2k while parked or is it while being driven? or both?
    Jan 2012
    Malton
    276
    Felt when driving and pulling through the rev range. There is also a kind of low frequency vibration that can be felt through the whole car bparricularly through the pedals. But strangely not through the steering wheel which is rock steady. I had the rear bearings replaced in January and had all the wheels aligned then. The vibration was barely perceptible in January but has got stronger over the months. Doesn't feel good. Almost impossible I know to identify when you are not in the car! Any ideas? Many thanks.
    Aug 2010
    1,540
    only while driving can you feel it? is it a quattro? might be a drive line viabration if its only on the move? prop center bearing?
    does it occour at the same sort of engine speed in each gear? is it more apparent in the higher gears, higher road speed, but still at around 2000 rpm you mentioned?
    Aug 2010
    1,540
    when you can feel it, does it go away if you press the clutch down and let the engine idle and "coast"?
    Jan 2012
    Malton
    276
    It's an Auto Quattro - there are two components to the vibration a kind of roughness at the 2 k point and then the lower frequency vibration which is a bit like driving over a slightly rough road surface. It sort of stays constant but I just realise that most of the time the car will be cruising at just under or around 2 k it kind of smooths a bit at higher speeds when the revs would be above the 2k point. I'll yak it out tomorrow and make some more exact observations. Drivetrain feels about right though. She's a 12 yr old car with 147000 miles done.
    Aug 2010
    1,540
    the lower frequency noise sounds like a drone from the exhaust tbh.
    in the front pipe of the exhaust there's a flexible section its supposed to isolate engine viabrations from the exhaust.
    over time this flexible secition seizes up with rust on the outside and soot/carbon on the inside.... this allows the engine viabrations to transmit through the exhaust. causing the low frequency revs specific drone i think your describing??
    Jan 2012
    Malton
    276
    Is it easy doable to replace?
    Aug 2010
    1,540
    not sure, usually the flexi bit is part of the same section the cat is in. ergo expencive!!
    in the past at work ive removed the full front pipe inc. the cat and welded in new flexi sections.......
    they look like this......
    50MM/45MM FLEXIBLE ALLOY CAR EXHAUST CONNECTOR/ADAPTOR | eBay
    any decent exhaust place would be able to weld you a new one in.
    any ideas from any other forum members?????
    Jan 2012
    Malton
    276
    So would it make sense to remove the cat if I replaced the flexi section? Thanks for your time and interest btw.
    Aug 2010
    1,540
    you can de-cat it if you want, its up to you.
    Jul 2007
    London
    3,209
    I think it's the propshaft centre bearing if it does it only on the move at that engine speed.
    FOR SALE:
    Jan 2012
    Malton
    276
    Is the propshaft centre bearing complicated to replace?
    Jan 2012
    Malton
    276
    spare bearing and houseing from the US http://www.audifans.net/ftopict-29318.html
    Seems the Parts are the problem - these are links that I found from other forums about how to do the work.
    Jan 2012
    Malton
    276
    Europarts is also mentioned as a supply company - any experience with them?
    Aug 2010
    1,540
    its just removing the prop (exhaust to come off aswell as the transmission tunnel heat shields). marking it up. split it (think theres a circlip) and remove the bearing.
    Jan 2012
    Malton
    276
    Many thanks - I will have a go and report back.
  1. A6 2.5 TDI --- Getting the Viscous Fan OFF
    By TYphoon GB in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th April 2012, 21:28
  2. TDi Fan on Constantly/ ECON light too!
    By N7 JNS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2011, 14:27
  3. A3 2.0 TDI fan problem
    By Gogs-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2008, 08:14
  4. A3 TDI Fan Stays On....
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2008, 13:24
  5. 2.0 tdi fan problem HELP
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2008, 23:00
