EM TuningAH Fabrications
Results 1 to 7 of 7
    Mar 2012
    Durban, South Africa
    13
    Brake pedal pulsating after installing repaired ABS module
    Hi all
    Just received my ABS module from ECUtesting in Derbyshire, UK.
    Yesterday upon installing, i was thrilled to see the faults were clear and my LCD now reads "OK" upon startup.
    However the brake pedal pulsates violently upon braking- at low speeds too.
    i would suspect the sensors as the ABS module has been faulty for a few years and the PO did not repair it.
    what are your thoughts?
    any links to DIYs will be appreciated.
    i dont yet have VAG COM but am shopping a cable.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    Appears to be common on B5s. Both of mine did this and I put up with it. Check the rear reluctor rings, most likely cracked or full of crud. Be very careful if you try and remove the abs sensors. They get stuck if been in a long time, break easily and cost a small fortune to replace.
    Dan
    2002 2.5 V6 Quattro
    Apr 2006
    A, A
    269
    LOL just bought a sensor today and it cost £164 with 10% off from Audi but includes the brass holder so be very carefull.
    Andy
    Mar 2012
    13
    you lot are really scaring me
    thanks will jack her up once again and get my hands dirty this afternoon. wife permitting :P
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,941
    sensors are on ebay for about 15quid and they work fine!
    It could be a bad sensor, incorrect airgap, or broken reluctor.
    TD5 Land Rover Defender build
    Mar 2012
    13
    Jan 2011
    Aberdeenshire
    635
    Looks like you found the fault then.
    Well done!
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
  1. Replies: 18
    Last Post: 14th February 2012, 23:35
  2. ABS module on the abs pump
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2010, 20:56
  3. trying to get airbag module repaired
    By dubmas in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2007, 20:23
  4. Can Airbag Control Module be repaired rather than replaced?
    By Rhunster in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2005, 15:29
