Volks AutosChris Nott
    Nov 2011
    lincoln
    46
    audi a4 1.8t both front windows not working, any ideas?
    right, when i put me sub in about 4 months ago. i used the hole in the bulkhead where the bonnet pull cable goes, any way never managed to get the gromit back to seal the hole, as i never noticed at the time, not much rain was fine, but the last month or so with the weather like it is there have been a swimming pool in me car drivers side front and back, so i tried sealing the hole with body panel selent. think i have stoped that but car is still slightly damp. right both front windows have stopped working and the drivers side is down alittle, carnt get it to go up, not by button, key in the door or holding the lock button for a bit, nothing works but every few days if i press the window switch the window goes down a tad, and then nothing. i believe they r linked to the central locking pump as once i disconnected it and they didnt work, any ideas? backs r windy so no prob there.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    Theres a thermal fuse up behind central electrics under the dash, maybe the water has damaged it?
    TD5 Land Rover Defender build
    Nov 2011
    lincoln
    46
    could you explain better where it is please aragorn. ;-)
    Jun 2010
    76
    Theres a huge fuse for the windows up behind drivers side of the dash if i remember, you need to screw off the bottom of the dash from the ignition to the pedals. It should be somewhere up high to the right.
    Nov 2011
    lincoln
    46
    thanks stoop44rio, will have a look.
    Nov 2011
    lincoln
    46
    just checked, and the fuse aint blow, just the contacts covered in crap, gave it a wiggle and hey presto. thanks again.
  1. auto windows not working
    By scott b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2010, 16:32
  2. Both front electric windows not working...
    By mitalm in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2010, 16:42
  3. Electric Windows not working?
    By audi58 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st January 2010, 21:43
  4. Help! All windows not working
    By DrewHughes in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2009, 10:25
  5. Windows stopped working??
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2008, 22:43
