EM TuningChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By aragorn
Thread: KO4 PARTS LIST REQUIRED PLEASE ON 1.8T B5 !!!
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    hi guys been on the hunt for a ko3s upgrade for my t-sport but keep geting told to go ko4
    so my friends i am in-need of a parts list on what i will need to upgrade from the ko3 to the ko4 ??
    and i can see this being expensive lol be gentle lol
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    you first need to locate a k05-14 turbo as they are rare and expensive. Seeing they are really only about as big as a k03s on a transverse, you will get away with just a decent intake and slightly larger injectors.
    The Longitudinal engine doesn't get a k03s, you could maybe try a hybrid?
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    I was going to go for a K04, but when I looked at getting one the cost versus the power gains made me rethink it, now will be going hybrid turbo route.
    Depends on what kind of power you are looking for?
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    so a ko3s cant go on mine then ?????? byzan
    as for power sulli well well we allways want more lol but got told it would do nicley around the 220 mark ??? but mi new to these 1.8 20v engines so dont know that much about them ,,
    most of my mates either got the a3's an golfs but i dindt want to do the same so chose a4
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    The turbo commonly referred to as a "k03s" is a transverse turbo, ie it only fits A3/Golf platform cars.
    As for required mods...
    Decent front mounted intercooler and a 2.5 or 3" downpipe with sportcat is a good starting point.
    As for the turbo itself, instead of buying a proper K04-015, you can modify your existing K03 (or i can sell you a standard turbo you can have modified and then install)
    You want the exhaust housing machined out the take the Turbine wheel from an S3, then you have a few options on the compressor side, either keep the existing housing and use either an RS4 compressor, or a 2077 ETT wheel. These will be good for around 240hp. If you want more, then you can use an S3 compressor, housing and backplate, which probably gives scope for around 260hp.
    Your choice of turbo will then dictate further mods.
    The original MAF maxes out around 230-235hp, so if you go with the smaller compressor and accept a max of around 230-235 then you'll get away with only an injector upgrade (C20LET Yellows)
    If you want to push for 240+ then you'll need to upgrade to a 3" MAF housing.
    Royh1179 likes this.
    TD5 Land Rover Defender build
    Jan 2012
    Langdon Hills/Southend
    41
    On mine I've gone a slightly different route to most people.
    I've used a K04-15, larger fuel pump, air filter, FMIC and a MBC with a Stage 3 chip although I'm running a standard CAT It was actually useless come MOT time so will at some point get a decat but at the moment it's boosting to 18psi and holding at 17.5psi to go further injectors would be the next step so as mentioned C20LET's or SAAB Reds are suitable as is a larger MAF I'm happy with it at the moment smooth power band and efficiently burning during combustion, half a tank of mixed driving has got me 186 miles
    As it's my daily I want to keep reliability rather than power and prolong the life of the components too
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    thanks guys if i see 230 ill be ok with that as like you JMills its my daily driver also so still need the reliability and efficiencey
    glad i didnt buy the k03s i was watching on ebay now lol
    so should the best bet be mod my ko3 or push for ko4 ??
    May 2010
    Bedford
    2,877
    Only thing i guess you could call an S would be a K03-73 from the BEX engined B6 1.8t 190 which should do 230ish but they`re even harder to find than a K04 so easiest bet would be what Aragorn said and get one built from your existing turbo.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    15,372
    The modified K03 i described is bigger than the real K04-015, so its a no-brainer, mod the K03!
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    modded ko3 then thanks for all your help guys much appreciated
    "Stick a V8 in it!"
    15,372
    Theres a chap on here called Beachbuggy thats built a few for people, might be worth dropping him a PM.
    If you need a spare turbo to build on then give me a shout.
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    ill look him up cheerz mate nice one and if i do require turbo then ill pm you cheerz
    jcb
    Sep 2005
    uk
    4,077
    I have some bits from a K04-001 (which I believe is a K03 with a bigger compressor wheel.)
    Royh1179's Avatar
    Jan 2012
    lincolnshire
    67
    hi jcb soz mate only just seen this post ill look into it and let you know cheerz what bits you got laying about ??
  1. A3/S3 Parts wanted list inside
    By chrisbond69 in forum For Sale/Wanted - Audi Parts
    Last Post: 26th March 2012, 16:50
  2. Ko4 check list
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2010, 14:50
  3. Cambelt Parts List
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2007, 19:42
  4. Cambelt parts list
    By RussUK in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2007, 22:39
