Volks AutosJMB Retrofits
    Jun 2004
    London
    21
    Loss of power. Turbo problems?
    My 1996 A4 1.8T Sport has lost a huge amount of power. I've had the gaskets on the turbo changed but this has not made a difference. Any ideas?
    May 2004
    Billericay, UK
    278
    Re: Loss of power. Turbo problems?
    Could be an air leak in the pressure side of the system of a buggered turbo...
    Probably a multitude of other things bit who knows.
    Hope this helps.
    Greg
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    check the cat...
    if in doubt get a decat pipe
    they are prone to twisting in the pipe and blocking
    Andy
    GDI
    Jun 2004
    London
    21
    What checks can I do to the cat?
    g
    AndyC's Avatar
    Apr 2003
    Dorset
    716
    take it out and try and look through it, with a light the other end....
    its 6 bolts and about an hour or so to do.
    if you would like us to do it, please call for a booking... I will be more than happy to show you... if its not that then we can pop it on the diagnostic scanner and see if there is anything else wrong
    I have a cat in stock as well!
    Andy
    GDI
