Sky InsuranceVolks Autos
    Mar 2012
    Rough running A4 1.9 TDI AHU
    Hi all,
    Having some problems with my A4 1.9 tdi, 1999, 189k.
    When I try to start the car the Glow Plug Light only comes on the odd time after turning the key a good few times, if there's no light the car won't start and when the lights on it starts then after a few minutes it has a rough idle issue.
    Had the car scanned with Vag Com and it showed up these issues
    18062-Please check DTC Memory of instrument cluster
    P1654-35-10- - Intermittent
    17964-Charge Pressure Control
    P1556-35-00- Negative Deviation
    17552-Mass Air Flow Sensor (G70)
    P1144-35-10-Open or short to ground - intermittent
    18027-Glow Plug Relay (J52)
    P1619-35-10-Open or short to ground - intermittent
    So I replaced the Mass air flow sensor, Glow plug relay (Mine was relay number 219 not 109) and had the errors cleared. Then tried to start the car but still no glow plug light until a few turns of key then it would start and after a few minutes the rough idle was back again.
    Scanned car again and its now showing 1 issue:
    01314- Engine Control Module
    49-10- No Communication.
    Any help would be great as I'am starting to lose faith.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,109
    IIRC this has been posted before and i think the ecu is the cause of this problem but i may be wrong, i tend to stay away from the derv's lol only petrol runs in my blood.
    Mar 2012
    Hi Bradderz_1988. Think it could be the ecu, going to do few more checks then maybe order a secondhand one and get it coded to the car.
  1. Running rough A4 avant 2.0 TDI B7
    By prs999 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd November 2011, 14:57
  2. HEEEELLLLPPPP!!!! - Rough running A4 Avant 2.0 TDI SLine (57 Plate)
    By oneightycd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2011, 19:55
  3. vw 1.9 tdi running rough
    By hul71 in forum General Automotive Chat
    Last Post: 8th May 2010, 20:39
  4. Why's My 2.0 TDI Running Rough on Idle? (With Vid)
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 12:18
  5. Problems with 2.0 tdi running rough when cold
    By Pedro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 17:25
